12-04-2007, 11:13 AM | #81 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
the tube chassis I threw together is 1/4 square aluminum, I have no luck Brazing :-( yet, but soldering, and my Mig welder has been easy with steel not liking the emaxx tranny, way to big, and I think 1st gear is toast Last edited by toy4crawlin; 12-04-2007 at 12:00 PM. |
12-04-2007, 11:29 AM | #82 |
Rock Crawler Join Date: Sep 2005 Location: IDK
| Why not leave all that aluminuim alone and lest start brazing steel, its way easier and works very well.
12-04-2007, 12:05 PM | #83 | |
Yea once I figure out how to get the Braze to work, the braze rod just melts into a ball and runs off. I heat the area a bit then put on the Flux then heat up but the flux leaves a white to burn surface on the metal so I clean it off with a stainless brush then I heat up again and add braze rod but it just runs off What am I doing wrong ? Wish I had a TIG | |
12-04-2007, 02:51 PM | #84 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
I didn't think you could Braze Aluminium...
12-05-2007, 05:33 AM | #85 |
You dont have to apply the flux when you already heated it, dont do that!. Firts on put some flux on the joint, then apply heat until the flux is melted and the material is red hot. If you did it right you'll see the joint become an other color than the rest of the steel, thats good. keep the meterial =(steel or brass, or even copper) RED HOT, (sort of cherry color). Now when its red hot apply some silver Solder and hold is between the flam and joint. Now it will cover up the joint and leaves a nice smooth surface. Hope this helped, this is the way i always do it and my joints are very strong indeed. ( i think) Succes ! |
12-05-2007, 05:35 AM | #86 | |
Keep heating it until the 'white burned flux' is melted, dont clean it cause you will undo the flux and you need the flux. | |
12-05-2007, 11:01 AM | #87 |
Hey thank you for helping out but you mean Braze rod not solder, right ? Also I thought you heat the steel or Aluminum until it's hot enought to melt the braze rod . |
12-05-2007, 11:39 AM | #88 |
you cant!! braze alu with normal silver solder. and the material needs to be red hot Now start practicing |
12-05-2007, 12:42 PM | #89 |
I have brazing rod for Aluminum, just have not been able to make work siler solder on steel is a peice of cake |
01-02-2008, 10:30 PM | #90 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
i wanna see some pics of the rig!! sweet build lots of orig. ideas |
07-29-2008, 01:15 PM | #91 |
I'm back in the game ! Started a new 1/4 DOM tube chassis and Almost Finished front DIG ! Researching to use a mini actuator instead of Bulky Servo MP3 Player loaded with tunes and recorded Engine sound for the Corvette motor ! I cut up the amplifier and speakers from Altec Lansing, ordered a Dual 100K ohm switch POT The MP3 player will mount on dash and the Custom steering wheel will Turn it on and Adjust Volume ! Last edited by toy4crawlin; 08-08-2008 at 11:05 AM. |
07-31-2008, 01:44 PM | #92 |
Just a mock up, this is not the final chassis or steering wheel I cut up a new Altec Lansing In motion speaker set . Very impressive little unit it sounds pretty good with Stereo sound . TOTAL CONTINUOUS POWER: 4 Watts RMS • Front Speakers: 2 Watts/channel @ 8 ohms @ 10% THD @ 20 - 20000 Hz 2 Channels Loaded SYSTEM RESPONSE: 100 Hz – 20 kHz SIGNAL TO NOISE RATIO @ 1 KHZ INPUT: > 75 DB DRIVERS: Two 25 mm full-range neodymium micro drivers and two 18 mm neodymium tweeters. The Player is a Sony Mp3 player with FM radio and recorder, so I recorded the engine and Exhaust sound on my 1:1 crawler to play on the super The stock volume was a dual Slide pot Volume only with a separate switch to power it on. So I am replacing it with a regular 100k 2ch Potentiometer with a switch it will be mounted to the steering wheel so to turn on stereo you turn the Steering wheel and adjust the Volume ! The Shifter switches will power on the Crawler radio/ESC , Lights Last edited by toy4crawlin; 07-31-2008 at 02:23 PM. |
08-01-2008, 11:40 PM | #93 |
Newbie Join Date: Jul 2008 Location: Bryson
| Wow
I'm so impressed with your build. You must be a machinist. Makes me want to get off my butt and build something. I am somewhat local. Would love to see your craftsmanship someday in person. Thanks for replying to my thread. Rich |
08-05-2008, 09:09 PM | #94 |
Hey thanks Nano I'm not a machinists, but it would be nice to have a mill & lathe I actually have been doing well using my drill press as a lathe Just found some 2.5 mm A/N Fittings and braiding and Blue air locker line Also Going to make a NOS tank from scratch, build pics to come Ordered a 5.7 Corevette fuel injected 1/12 scale engine |
08-07-2008, 11:48 AM | #95 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Been using Detail Masters fittings for static models for years - great stuff. Kisckass build by the way! I wish I had the talent to wire something like that up. How did you learn? Are you a tinkerer or an engineer or something? Subscribed.............. |
08-07-2008, 02:19 PM | #96 |
Hey Thank you Been a tinker /modifier since I was 8 when I had 2 tonka trucks It's in the blood .. speaking of building.. Built my own street luge and Won 2004 World Championship in two classes Against 9 nations after only 5 years of Competition word Racing . not one bone broken ,no stitches. TOP Speed 68 MPH 6061 T6 aluminum and lexan, 8 wheels, 32 skate bearings, 38 lbs Have been all over the World, Sweden-denmark-Copenhagen (Hot girls), Switzerland, Germany, France, Austria, South Africa, Brazil, Montreal Canada ! Best experience of my LIFE ! 3rd pic is about 60 mph Forgive me of the Scratches and rough condition-- it's been through A lot ! Last edited by toy4crawlin; 08-08-2008 at 11:08 AM. |
08-08-2008, 12:32 PM | #97 |
Rock Stacker Join Date: Aug 2008 Location: Portland
Those axles are insane!
08-08-2008, 12:55 PM | #98 |
DOm Chassis Build begins ! thanks for the Tubing SlinkySam 1/4 DOM tube, Fully Mig welded (could not get braze to work) Custom AXLE with 120 Degree Steering ! Max Big bore shocks nitride. Drew a Sketch Driver Wild willy arrived in mail Last edited by toy4crawlin; 08-22-2008 at 10:06 AM. |
08-08-2008, 01:44 PM | #99 |
Engine just arrived |
08-09-2008, 11:14 AM | #100 |
Quarry Creeper Join Date: Aug 2008 Location: Yes yes, it is.
| when is the vid?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/large-scale-rigs/66983-project-full-throttle-super-comp-crawler-mp3-stereo.html | ||||
Emaxx-Revo-Losi 1/5 AWD On-Road racer - Page 2 - RC-Monster Forums | This thread | Refback | 03-01-2013 04:11 PM | |
Toyota vs Jeep discussion? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 02-27-2013 05:55 AM |
