07-24-2007, 03:14 PM | #21 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
yea lets see em |
07-24-2007, 08:33 PM | #22 |
I joined the Band! Join Date: Sep 2006 Location: ...
07-26-2007, 07:56 PM | #23 |
I joined the Band! Join Date: Mar 2007 Location: woodstock
update
07-27-2007, 03:27 PM | #24 |
Quarry Creeper Join Date: May 2007 Location: Temecula, CA
I just bought 2 1:6 CXT they will be in on Monday. This Will be my first build in a long time. The chassis and links Will be made of Carbon Fiber as for the color I don't know yet. The Carbon Fiber colors I have are Black,Red,Blue,Yellow and silver. What motors and servos should I run?
07-27-2007, 11:01 PM | #25 |
welcome to the forum. and im running a 55t lathe motor and 3300mah batterie. it seems to work good at half throttle. and i get around 45min of run time. -bronco |
07-28-2007, 07:59 AM | #26 |
Thank you for the welcome. I was thinking of running 85T lathe motors and HS645 servos for the 1:6 CXT with 2-6 cell batteries will this combo work? These are big trucks and I want to make a sled for truck pulling since I can't rock crawl too much in this big truck. This is a pic of my full scale truck. Last edited by JJR; 07-28-2007 at 10:16 PM. |
07-28-2007, 08:32 AM | #27 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
I would go with some 65t motors then if its needed run a reduction on it like a gd-600 but if you are going to pull with it you will need some wheelspeed and with 85t motors you would most likely go about a foot then just bury the truck.
07-28-2007, 06:08 PM | #28 |
RCC Addict Join Date: May 2006 Location: Aroostook county
| No, you're gonna want 35t magnetic mayhems, or a brushless set-up.
07-28-2007, 06:23 PM | #29 |
Well if he was planning on using 85t motors then i think a 35t wont have enough torque hes building a puller so it will have quite a bit of weight in the front to hold it down. I would say 45t at the lowest. 35t would be not nearly enough torque
07-30-2007, 09:48 AM | #30 |
| DROOOOOL!!! |
08-11-2007, 07:49 PM | #31 |
welp, the build is going no further. i parted most of it out....heres an update before it was parted.... |
