Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: attention Shafties, tranny setup and gear Ratio
Closed Thread
Old 08-20-2007, 12:11 PM   #1
toy4crawlin's Avatar
Default attention Shafties, tranny setup and gear Ratio
Any of you ( Pro's or Comp guys, or bashers prefer to have the trans setup so that if let's say one of the rear wheels becomes stuck and cannot turn but the motor still turns the Front Wheels ?
Or Do you like the Slipper to Slip entirely so if any of the 4 wheels cannot turn all power is lost and slips into the slipper, thus saving from breaking axles?
I'm thinking the first way is best.
also where is info to figure out gear ratio's ?
and what ratios are best?
thanks
toy4crawlin is offline
Old 08-20-2007, 03:46 PM   #2
Wow not very busy here.... guess I will delete this tonight
With center diff you only loose front or rear drive Not both at the same time , isn't that better..
Old 08-20-2007, 03:54 PM   #3
slugzracing's Avatar
Wow you are impatient
If you had wanted opinions on power transfer for shafties you should have asked in General Crawlers and not the scale forums.
slugzracing is offline
Old 08-20-2007, 03:58 PM   #4
PapaGriz Yo
Grizzly4x4's Avatar
No need for two posts with the same question. Please see the other thread if you want to reply.
Grizzly4x4 is offline
Closed Thread
