02-05-2014, 11:13 AM | #61 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Locked Up RC - FI Spool
Should be getting my pair this week sometime.
02-08-2014, 05:35 PM | #62 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
I want to get some spools, but the website says its out of stock.
02-08-2014, 11:06 PM | #63 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Re: Locked Up RC - FI Spool |
02-08-2014, 11:11 PM | #64 |
| Re: Locked Up RC - FI Spool Down under orders go through 110 Crawlers: Onetencrawlers.com.au I do not think they have any in stock at the moment, but we are making a good sized shipment to them on Monday so they should have stuff in stock very soon. |
02-09-2014, 05:53 AM | #65 |
Order placed...money sent. Now the hard part...the wait! I will be looking to order 4 more lockers in the future. 2 for my rubicon and 2 for my deadbolt. |
03-13-2014, 02:01 PM | #66 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
Received these spools but the Axial axles are a bit tight and need some grinding, what technique works best in grinding them?
03-13-2014, 03:06 PM | #67 | |
| Re: Locked Up RC - FI Spool Quote:
So for a easier time changing shafts ... sand paper will work. Any sort of file will work. I prefer an emery board. Whatever you use you want something that is a finer grit (240+) because you are really just polishing these and not looking to remove a lot of material. While doing the steps below I am constantly checking to see if I can get the shafts in. Once they go in just a little, I tap them in the rest of the way. Put a nut on the end of the shaft that hangs off a hair (so you don't damage the threads) and use a little hammer to convince it. Then remove them and repeat until the fit is snug but something where you can get the shafts out easily enough for the field. Take note of which one goes in which side too as things can vary. 1. Start by ensuring the end of the shaft is totally deburred and put a little chamfer on it to help guide it in: 2. Next (if necessary) I take a little off this outer portion (on both sides). You can chuck the shaft up in a cordless drill and spin it while holding pressure on it with the emery board/paper/file: 3. If that doesn't seem to solve it, you can start to take a little off off this portion just do your absolute best to keep it as level and even side to side as you can: Last edited by Locked Up; 03-13-2014 at 03:08 PM. | |
03-13-2014, 11:39 PM | #68 |
Thanks for the tip. It seems like its the straight axle that has a tight fit. The Axial universals went in OK. I ended up hammering the straight axle. Its not going anywhere with the beeftubes in there.
03-18-2014, 12:06 PM | #69 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
I just smash them in, tight as a nun. Sent from my iPhone using Tapatalk |
03-27-2014, 05:09 PM | #70 |
Newbie Join Date: Aug 2009 Location: ventura county
These lockers are the best I've used out of 3 different companys, super tight with perfect fit..
04-20-2014, 03:55 PM | #71 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
Just ordered a pair since the GCM lockers keep loosing up and i hate to disassermble to retight and loctite up everything so i hope this are the last lockers i bought. I used to have HR ones but they won't hold up and gained a lot of slop, like 1/4 turn |
04-20-2014, 06:25 PM | #72 |
| Re: Locked Up RC - FI Spool You will be very happy with these, I have bought enough in the past month to do all my SCX10 based axles. I am even going to run them in my sportsman I am currently building. They are tough and very well made. |
04-20-2014, 08:22 PM | #73 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
I can confirm that, the only slop I get with them is in the front axle, and it comes entirely from the CVDs! The back axle is rock solid, absolutely no slop at all! Sent from my XT1032 using Tapatalk |
05-19-2014, 06:38 PM | #74 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Just ordered a couple, tired of set screws!!! |
05-21-2014, 01:35 PM | #75 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
You should do a run of these in Ti |
05-25-2014, 07:44 AM | #76 |
| Re: Locked Up RC - FI Spool Just ordered another pair of those, please include me the scale decals you didn't include me the first time |
05-25-2014, 03:36 PM | #77 | |
I highly recommend LockedUpRC, the only wheel vendor (who obviously sells lots of other nice stuff) who replied after I used the contact part of their website, he replied later the same day and answered all my questions! I ordered through his website on 5/22/14 (from Texas) with standard shipping and they showed up in Norcal today 5/24/14!!! Everything was packaged very well, are very high quality and great guy to deal with, will buy from again! EDIT: Here they are: Add these great peel & stick decals to your rig to help complete the scale look! Each pack includes: 2x logo decals (~38mm x 10mm) 2x locker decals (~12mm x 8mm) 1x blue windshield banner decal (~42mm x 4mm) 1x black windshield banner decal (~42mm x 4mm) 1x white windshield banner decal (~42mm x 4mm) http://www.lockeduprc.com/Locked-UP-...ack_p_340.html ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~ Here's some bigger ones for a couple bucks, : Discount pack of all white vinyl decals! Each pack includes: 3x logo decal (~99mm x 27mm) on white vinyl http://www.lockeduprc.com/Locked-UP-...ack_p_398.html Bigger ones For those of you that asked for slightly larger stickers, we present our "Team" decal pack including 3 die cut decals. Each pack includes: 1x logo decal (~99mm x 27mm) on white vinyl 1x logo decal (~99mm x 27mm) on clear with white slogan 1x logo decal (~99mm x 27mm) on clear with black slogan http://www.lockeduprc.com/Locked-UP-...ck-_p_397.html Last edited by Natedog; 05-25-2014 at 03:41 PM. | |
05-25-2014, 09:32 PM | #78 |
05-25-2014, 10:13 PM | #79 |
Man these things are a tight fit! I have a good analogy that involves my wife, but I'm sure I'd get my ass kicked if she ever read it! |
05-25-2014, 10:58 PM | #80 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Your wife is a nun?
Locked Up RC - FI Spool - Similar Threads | ||||
traxxas slash 4x4 spool or no spool? | Oregon crawler | Formula Offroad | 12 | 03-17-2012 02:02 PM |
Diffs locked or not locked? | aorquiz | Formula Offroad | 8 | 05-20-2011 09:58 PM |
Spool | mtwheelin | Tamiya TLT Crawlers | 9 | 08-04-2007 12:04 PM |
Axial AX10 Locked Axle Set and Locked Transmission | Xtant3150c | General Crawlers | 13 | 07-22-2007 01:39 PM |
