05-28-2014, 08:53 AM | #81 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: Locked Up RC - FI Spool |
06-19-2014, 03:39 PM | #82 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
can i order them here?because i visited your page but it say that i have not met the minimum order?what is the minimum order?
06-20-2014, 06:55 AM | #83 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Re: Locked Up RC - FI Spool I'll look into it.
06-22-2014, 12:13 PM | #84 |
any help?
06-23-2014, 09:36 AM | #85 |
| Re: Locked Up RC - FI Spool There is a minimum of $100 for orders in your area and payment must be made via western union. Thanks, Patrick Last edited by Locked Up; 06-23-2014 at 09:38 AM. |
07-16-2014, 09:07 PM | #86 |
Rock Crawler Join Date: Oct 2011 Location: Canada
At a bit of a loss, I am using them with the HD overdrive gear set and CV universals. They wouldn't come close to going in.. so tap tap tap with a hammer (lightly) and in they went. But now it's as if they are not straight, and I get a gear grind/resistance in one spot during rotation after axle reassembly. The shafts are not bent, just don't seem to seat at that perfect perpendicular angle to the locker. They are absolutely impossible to remove. I fear bending one of the CV shafts. Now I am just stuck and don't know what to do from here. Anyone have any experience?
07-16-2014, 10:40 PM | #87 | |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: Locked Up RC - FI Spool Quote:
The FI Spools have a very, very close tolerance and some shafts may require a bit a filing. I had to remove just a hair off my front RC4WD shafts with a file. Do you have the axle apart and the spool and shaft out of the housing? | |
07-17-2014, 06:23 AM | #88 |
Yes everything is a new build so I haven't put it all together yet. I just have to figure out how to get the shafts out of the locker now. I may try a vice as not to bend the shafts while pulling. They went in so easy with a few light taps, I thought I was home free. I'll keep at it, it's not a product problem, the locker is flawless in it's engineering, more of an operator error.
07-17-2014, 08:29 AM | #89 | |
07-17-2014, 10:02 AM | #90 |
Pebble Pounder Join Date: May 2013 Location: Torrance
I just got two and I like them so far. They were a super tight fit with xr axles in my curries. A couple taps and they were in. Absolutely zero slop. I just wish we could use m3 hardware for the ring gear. That's what I broke with my other locker. They sheared off and tore up my axle center section.
07-18-2014, 06:40 AM | #91 |
Issue solved. I am running the Locker with Axial Uni's and OD front HD Gears. After so much frustration it turns out that the plastic axial axle housings are slightly warped. When re-assembled they pull the locker/gear set into the pinion every half rotation. I am just going to shim out the locker/gear set for now and it will clear up the problem. This set deserves aluminum housings, so I better get on that soon. I gotta tell ya, these spools ARE F.I. I beat the crap out of mine trying to get stuck shafts out! I viced them, clamped them, blow torched them and even froze them with liquid nitrogen. They are an incredible little piece of hard ass steel. They are still true, still tight and not a mark on them. *Edit I have now installed them WITH the stock axial gasket between the spool and the gear. It seems that in my case the extra 1/32" shim of the gasket was needed to get the perfect mesh running the Axial HD Overdrive gears. If your binding, I would suggest this trick. Last edited by Arctic Fire; 07-18-2014 at 02:35 PM. |
09-11-2014, 03:14 PM | #92 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
I just bought and installed two of these. The stock Axial rear axles fit nice and tight, but the RC4WD CVDs are still slightly wobbly in their sockets. Is that normal?
09-12-2014, 08:19 AM | #93 | |
If the Axial are tight and the RC4wd are loose I would suspect the RC4WD shafts to be a bit smaller than ideal. This is not to say there is anything wrong with the RC4WD parts or the lockers. Even with tolerances smaller than a human hair, a hint of slop in the socket will amplify out at the tires. If you have a dial caliper and/or want to troubleshoot with us, drop us a ticket on the contact us tab of our website. Depending on how bad it is there are some different things we could try to help you shim out the slop. | |
09-16-2014, 05:48 PM | #94 |
Rock Stacker Join Date: Jan 2012 Location: Walters, OK
I just tried to buy two of these. It rejected my card, so I used a different one. Same results. So I used a paypal account and some other BS popped up. Is there anywhere else that actually keeps stuff stocked that I can order through? Sent from my iPod touch using Tapatalk |
09-17-2014, 04:33 PM | #95 | |
The actual amount of wobble is very small, about the size of one tread block on the surface of the tire. It's not significant, I had just expected it to fit like they were welded together based on the product description. | |
09-17-2014, 07:19 PM | #96 | ||
I don't see any stock at our distributors at the moment. If you send a note to us on the contact us tab of our website I'm happy to try to get something sorted out for you! Quote:
Your lockers or axles may be on the high/low end of the tolerance zone. If you can, please send us a note on the contact us tab of our website. That way we can track this, add it to our knowledge base and provide you faster support! | ||
09-26-2014, 07:06 AM | #97 |
Newbie Join Date: Aug 2013 Location: Georgia
Will These Work on the front of the Axial Yeti to lock the front Diff ?
11-02-2014, 01:10 PM | #98 |
Pebble Pounder Join Date: Jul 2012 Location: USofA
11-03-2014, 07:32 AM | #99 | |
Check out the post we just shared on our facebook page: https://www.facebook.com/LockedUpRC I don't have a Yeti yet myself so I'm not sure what all you need to make this it work correctly. Post by Locked Up RC. Last edited by Locked Up; 11-03-2014 at 07:38 AM. | |
12-29-2014, 02:45 PM | #100 |
If you want to run an FI spool in the front of your Yeti, put retaining springs in the outdrive cups even if the cups fit tightly into the spool at first, because they *will* loosen up eventually.
Locked Up RC - FI Spool - Similar Threads | ||||
traxxas slash 4x4 spool or no spool? | Oregon crawler | Formula Offroad | 12 | 03-17-2012 02:02 PM |
Diffs locked or not locked? | aorquiz | Formula Offroad | 8 | 05-20-2011 09:58 PM |
Spool | mtwheelin | Tamiya TLT Crawlers | 9 | 08-04-2007 12:04 PM |
Axial AX10 Locked Axle Set and Locked Transmission | Xtant3150c | General Crawlers | 13 | 07-22-2007 01:39 PM |
