09-20-2015, 10:04 PM | #101 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Locked Up RC - FI Spool
I have three, they've all been fine. Worst case, press the bearings on over a piece of a ziploc freezer bag and trim off the excess. (To act as a very thin shim.) Every vanquish knuckle I've bought has needed that, as the bearings free spin in the VP holes. |
09-20-2015, 10:14 PM | #102 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Saran wrap works as an even thinner shim. I haven't had this problem though. Mine have been rock-solid for over a year now, and the bearings fit just right. |
09-21-2015, 10:34 AM | #103 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Skerb, Sorry you are having issues. To get to our customer/product support and arrange a return/exchnage is to submit a ticket on the website "contact us" tab: https://lockeduprc.3dcartstores.com/...tion=contactus We do get on here frequently ... but that is monitored MUCH more and all returns/exchanges have to go through there anyway. That OD being small has not been a problem in the past. In fact, we used to get complaints they they were too tight! As with all things, there will be minor differences from part to part but if they are to loose for you we are happy to take those back and exchange them. The guys in support can even double check the measurements of the parts they send you. Last edited by Locked Up; 09-22-2015 at 12:13 PM. |
09-21-2015, 07:54 PM | #104 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
Not using the stock gaskets, and lockedup is taking care of me, got 4 new spools on the way, thanks!! Sent from my iPad using Tapatalk |
10-23-2015, 01:07 PM | #105 |
Just to let you guys know ... BEWARE OF IMITATIONS! Steveo 151 and Klampykixx both have lockers that looks VERY SIMILAR to ours ...but are made to fit some off brand gears. If you get one of these off brand lockers, it's NOT going to work with Axial gears, VP housings, etc: locker does not fit gear help |
10-29-2015, 07:16 AM | #106 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
Just got two of the FI spools and they fit perfect. The bearings went on fine. When you say tight you don't joke lol. It loosened up a little after I worked it in and out a few times with some lube. I replaced my set screw lockers with these and I'm impressed. Good job LU |
01-06-2016, 01:11 AM | #107 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
Do you use the stock axial gearbox gasket when using these spools, or just screw spool directly to gear? Thanks! |
01-06-2016, 07:41 AM | #108 |
No gasket required.
04-02-2017, 01:38 PM | #109 |
Quarry Creeper Join Date: Aug 2008 Location: Sweden
Hello i recently got my second FI spool but it seems like one of them is missing the inside grove for the axle shafts? Giving me a huge play on one side of my axle! Last edited by Haziza; 04-02-2017 at 01:51 PM. |
04-04-2017, 01:01 PM | #110 | |
| Re: Locked Up RC - FI Spool Quote:
Chuck responded to your ticket on our site Sunday evening. If you were logged into your account on our site when you submitted the ticket, you can log in and check it. If you were not logged in to your account when you submitted the ticket then you will want to double check your email spam folder. | |
04-21-2017, 10:03 AM | #111 |
Found the issue Jeff. Sent you a PM and a note on our site. If you can, please confirm your address for us on the site and we can send out what you'll need to correct that. If anyone else has the same issue, please send us a note on the site so we can correct it for you. And please make sure you add lockeduprc.com to your safe senders list in your email. We get lots of people that think we are not replying ... but we do respond 100% of the time! |
04-22-2017, 09:21 PM | #112 |
Fun fact: The FI Lunchbox spool also works in the HPI RS4: A spool in the front is a quick and easy way to make most touring cars handle more consistently when cornering hard, but nobody makes spools for the RS4 for some reason. This convenient crossover is brought to you by the fact that Axial copied many of the critical dimensions from the HPI RS4 / MT2 / Wheely King / Crawler King diffs, and the FI Lunchbox spool was made to fit inside an Axial diff. Last edited by fyrstormer; 03-29-2018 at 07:14 PM. |
04-24-2017, 09:23 AM | #113 |
Well that is a fun fact! Do you mind if we hijack some of those pictures for the site? |
04-24-2017, 10:09 AM | #114 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
How far out are you for a production run. Checked the site the other night, and several things for the wraith said to be out on a waiting list.
04-24-2017, 10:31 AM | #115 | |
Anything made by Axial will be a while but if it is something we produce ... We are constantly restocking things. We should have more FI spools ready this week. Heavyweight spools will have limited quantities this week or next. If you are looking for slipper eliminator kits those will be a couple of weeks. I thought we would have some done up this week but I forgot to check the pin holes before finishing them. So they need to be remade. Not very happy with myself on that. Other things it just depends. More 2.2 wheels are getting wrapped up this week and some color options in the next 2 weeks. Looking at color rings coming during the next couple of weeks & months. If there is something specific you can always harass Chuck by sending in a ticket to ask. Sometimes he knows, sometimes he doesn't because sometimes we have to put out a fire | |
04-24-2017, 10:45 AM | #116 |
Okay. I thought maybe you were cutting the axial gears in house. I was looking for those, the FI spool, and rear axleshafts.
04-24-2017, 11:10 AM | #117 | |
Wraith Diff gears we currently carry are pure Axial. We are working on some for the 10-ii and might get back around to doing some for the Wraith/SCX10 but no time frame on that. | |
04-24-2017, 10:41 PM | #118 |
| Re: Locked Up RC - FI Spool |
04-25-2017, 11:40 AM | #119 | |
RCC Addict Join Date: Aug 2008 Location: Paulina
New 2.2 designs coming? Or more of available designs? Perhaps the Demon ring in 2.2 for the LockedUp wheels? Last edited by calcagno45; 04-25-2017 at 06:53 PM. | |
04-25-2017, 04:00 PM | #120 | |
Sticky aluminum-foil tape also makes good gaskets for nitro engines, btw. Stick one or two layers of that stuff over an opening, cut out the center with a hobby knife, and assemble the mating parts together. | |
Locked Up RC - FI Spool - Similar Threads | ||||
traxxas slash 4x4 spool or no spool? | Oregon crawler | Formula Offroad | 12 | 03-17-2012 02:02 PM |
Diffs locked or not locked? | aorquiz | Formula Offroad | 8 | 05-20-2011 09:58 PM |
Spool | mtwheelin | Tamiya TLT Crawlers | 9 | 08-04-2007 12:04 PM |
Axial AX10 Locked Axle Set and Locked Transmission | Xtant3150c | General Crawlers | 13 | 07-22-2007 01:39 PM |
