01-29-2014, 02:47 PM | #21 |
| Re: Locked Up RC Straight Axles - OT Shafts |
02-14-2014, 05:38 PM | #22 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I wanted to post up my results with these shafts. I have had them in my C2 rig for 3 comps now. Last comp the rig took two of the worse tumbles it ever has. Happy to report that the shafts held up great and run true as an arrow. Thanks for another great product Patrick. Edit : I should mention these were proto's, Patrick can confirm if they are the same as the production models. |
02-14-2014, 05:52 PM | #23 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Re: Locked Up RC Straight Axles - OT Shafts Quote:
Do yours get fat or neck down in the middle like this pic? http://www.lockeduprc.com/thumbnail....axx=425&maxy=0 | |
02-14-2014, 07:51 PM | #24 |
And I don't remember.... |
02-14-2014, 09:10 PM | #25 |
02-16-2014, 07:28 PM | #26 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
I installed my FI spools just after it came out and I had to do a bit of grinding on the axleshafts for them to fit properly. I plan on buying OT shafts and a new FI spool for the rear axle (I was one of the first to install the FI spools and I didn't do enough grinding on the rear axleshafts so the axle shafts where hammered in firmly in the FI spool and to this day I haven't been able to remove them ). Will the OT shafts be a direct fit in my "new" FI spool or will I have to do some grinding? PS: Not to hijack this thread but the FI spools are simply amazing, I can't wait to get the OT shafts on my rig Edit: Thanks a bunch to Jslick who helped me a ton with the FI spool install Last edited by TrailAddict; 02-16-2014 at 07:37 PM. Reason: Mention Jslick |
02-16-2014, 07:41 PM | #27 | |
Next run will probably see the tolerance get a little tighter. I feel like the current batch is too easy and I want yall to have to work for it. | |
02-16-2014, 08:01 PM | #28 |
02-18-2014, 05:37 PM | #29 |
| Re: Locked Up RC Straight Axles - OT Shafts Thanks, nice to be able to actually speak with the designer and maker of such nice products . When is the "next batch" taking place?
02-18-2014, 07:42 PM | #30 | |
We actually have lots of these in stock so it will just depend on when we run out of version 1 & 2. Speaking of, version 2 will be available before too long. It's a slightly different design so we will see what yall prefer. | |
02-19-2014, 06:37 AM | #31 |
Rock Stacker Join Date: Jan 2007 Location: Carson City
Is there any chance that there will be some coming out for the Wraith in the near future??? |
02-19-2014, 07:12 AM | #32 |
03-13-2014, 08:28 AM | #33 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
Received these yesterday and wow! If locked up rc was a woman I'd hook up with her fast and easy!:eek:
03-13-2014, 11:10 AM | #34 |
Version 2 now available! Locked Up RC is happy to announce our second solution for those that are looking for a stronger, reasonably priced, replacement rear axle shaft for their AX10/SCX10.... our OT 2 Shafts. These shafts replace Axial part# AX30424 (axi0424) Our OT 2 shafts are made of 1541H steel and offer a torsional tensile strength rating of over 160in/lbs. That is roughly 33% more than a typical stock shaft, which suffers complete destruction in the 120in/lb range. OT 2 Shafts also offer a higher yield strength while still retaining a good yield point and are a great supplement to our FI Spools. We wanted to make these beefy everywhere so they will be a "tight" fit on stock SCX10 (narrow Axial) wheel hexes. They "should" slide right through a standard Axial Hex. If your shafts do not slide in we suggest lightly filing the inner part of your hex to get them through. A rat tail file or coiled sandpaper will do the trick. It is a tight fit but just barely. With that beef comes less machine time and so they are a hair cheaper than our standard OT shafts! That beef also mean there is less torsional flex in them. Suffice to say when you hit the gas, these move out!! Compared to our "Standard OT" version and an Axial standard straight axle: No animals were harmed in the making of this product... Replacements for Axial SCX10 . AX10 steel straight axle 6x104.5mm (2) |
03-13-2014, 03:19 PM | #35 |
When do we get these for ar60s?
03-13-2014, 04:40 PM | #36 |
03-13-2014, 05:05 PM | #37 |
03-13-2014, 05:08 PM | #38 |
03-14-2014, 06:49 AM | #39 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
Any chance you can make these a bit longer for guys that want to run Wraith lockouts to match the extra front width when doing the XR10 mod?
03-14-2014, 11:17 AM | #40 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Locked Up RC Straight Axles - OT Shafts - Similar Threads | ||||
RC Axle Master's Straight 4340 Chromoly Straight Axles | Cruzin Illusion | EnRoute Berg | 48 | 08-29-2009 06:07 PM |
New Berg Straight Rear Straight Axles Survey | LetsHandleit | EnRoute Berg | 31 | 07-30-2009 07:58 PM |
Straight Axle Shafts | NICKC | Tamiya TLT Crawlers | 1 | 02-11-2008 04:41 PM |
