01-21-2014, 11:18 PM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Locked Up RC Straight Axles - OT Shafts Locked Up RC is happy to announce our solution for those that are looking for a stronger, reasonably priced, replacement rear axle shaft for their AX10/SCX10.... our OT Shafts. These are direct replacement shafts requiring no modifications to a stock vehicle. Using a custom jig I have tested and destroyed over 40 shafts of varying design and material over the course of the last month. As far as bang for the economical buck goes these are the best combination out there and we think you will enjoy them. ------------------------------------------------------------------------------------------------------------ Version 2 now available! Locked Up RC is happy to announce our second solution for those that are looking for a stronger, reasonably priced, replacement rear axle shaft for their AX10/SCX10.... our OT 2 Shafts. These shafts replace Axial part# AX30424 (axi0424) Our OT 2 shafts are made of 1541H steel and offer a torsional tensile strength rating of over 160in/lbs. That is roughly 33% more than a typical stock shaft, which suffers complete destruction in the 120in/lb range. OT 2 Shafts also offer a higher yield strength while still retaining a good yield point and are a great supplement to our FI Spools. We wanted to make these beefy everywhere so they will be a "tight" fit on stock SCX10 (narrow Axial) wheel hexes. They "should" slide right through a standard Axial Hex. If your shafts do not slide in we suggest lightly filing the inner part of your hex to get them through. A rat tail file or coiled sandpaper will do the trick. It is a tight fit but just barely. With that beef comes less machine time and so they are a hair cheaper than our standard OT shafts! That beef also mean there is less torsional flex in them. Suffice to say when you hit the gas, these move out!! Compared to our "Standard OT" version and an Axial standard straight axle: No animals were harmed in the making of this product... Replacements for Axial SCX10 . AX10 steel straight axle 6x104.5mm (2) Last edited by Locked Up; 03-13-2014 at 11:11 AM. |
01-21-2014, 11:23 PM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: Locked Up RC Straight Axles - OT Shafts
Nice work! I may have to get a set, the STRC ones just don't hold up. ♦♦♦♦ Land Rover Defender 90 Truggy ♦♦♦♦♦ |
01-21-2014, 11:34 PM | #3 | |
| Re: Locked Up RC Straight Axles - OT Shafts Quote:
01-22-2014, 01:01 AM | #4 |
Newbie Join Date: Aug 2010 Location: Sydney, Australia
Keen to get my hands on a set and give them some punishment! |
01-22-2014, 05:30 AM | #5 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
The FI spool stood for Fricking Indestructible. What does the OT shaft stand for? Very nice product BTW .
01-22-2014, 09:50 AM | #6 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Been a long time coming, thanks for getting these to market Patrick. |
01-22-2014, 06:11 PM | #7 |
What is the weight for the pair? They are great looking shafts. And great price too! |
01-22-2014, 06:34 PM | #8 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Can't wait to put a set of these through the ringer..
01-22-2014, 06:41 PM | #9 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
| Re: Locked Up RC Straight Axles - OT Shafts |
01-22-2014, 07:48 PM | #10 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
01-23-2014, 12:14 AM | #11 |
My postage meter says 24g (about .85oz) for a pair. |
01-23-2014, 12:27 AM | #12 | |
OT (One Third) sounded better than "33 Shafts" so ... Last edited by Locked Up; 01-23-2014 at 07:09 AM. | |
01-25-2014, 09:32 PM | #13 |
Think a set of wraith axles shafts will be next on line!? Not many options out for those!
01-25-2014, 09:51 PM | #14 |
01-25-2014, 11:07 PM | #15 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
Will they fit through beef tubes I couldn't tell if the flange was smaller than the stock ones
01-25-2014, 11:17 PM | #16 |
01-25-2014, 11:33 PM | #17 |
| Re: Locked Up RC Straight Axles - OT Shafts From the ones I have that I just got it appears they are just over 6mm so it would barely clear I used my caliper and 6 moved in and out freely but not by much space I think I.D. is around 6.5mm to 7mm at the very most
01-27-2014, 10:11 AM | #18 |
OT "Over Time" Need to order up a set, great addition to my drivetrain. |
01-27-2014, 09:02 PM | #19 | |
.5mm doesn't sound like much but in this game .05mm can be huge... let alone .5mm. I suspect the worst case would be you chuck it up in a drill and turn it down with some sand paper. <5 minute operation if it's even necessary. | |
01-29-2014, 02:46 PM | #20 | |
Locked Up RC Straight Axles - OT Shafts - Similar Threads | ||||
RC Axle Master's Straight 4340 Chromoly Straight Axles | Cruzin Illusion | EnRoute Berg | 48 | 08-29-2009 06:07 PM |
New Berg Straight Rear Straight Axles Survey | LetsHandleit | EnRoute Berg | 31 | 07-30-2009 07:58 PM |
Straight Axle Shafts | NICKC | Tamiya TLT Crawlers | 1 | 02-11-2008 04:41 PM |
