10-24-2014, 11:04 AM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Questions, suggestions and contact information If you have a question or issue with an order you placed, please submit a ticket -->HERE<-- The ticket system help us ensure things do not get overlooked or lost in the posts/PMs on this forum ... because this place is busy! As a small business based just outside of Austin, Texas, we are working hard to provide the best customer support that we can and every ticket is responded to by our staff. We type/speak English (and type bad Spanish) but we admit, you might get a little Texas twang! On the other hand, if you have a general comment, suggestion or feedback, please feel free to post up in this thread or the individual product threads in this section. We started small and are growing with your continued support. A huge thanks to all of our customers, past, present and future! -Patrick Norton ---------------------------------------------------------------------------------------------------------- A few of our Build Threads: TRX-4 TF2 Blazer Unimog Beast II 6x6 SCX10 II SCX10 H2 Wraith King Jero What the Vuck?! Wheely Kings SMT10 Ambush HexaMAN 6x6 Last edited by Locked Up; 12-13-2018 at 04:28 PM. |
10-24-2014, 04:55 PM | #2 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: Questions, suggestions and contact information
Please make the iKari slw in 1.9 thanks |
10-25-2014, 10:18 AM | #3 |
| Re: Questions, suggestions and contact information It is on the project list! Last edited by Locked Up; 02-12-2019 at 09:54 PM. |
01-06-2015, 10:33 PM | #4 |
Rock Crawler Join Date: Aug 2012 Location: Koloa boy 808 2 DA 206
Just wondering I have 2 Fi spool lockers that I just ordered both are different as far as thickness Im not able to install it in my curries just wondering if this is normal? I swap it out with stock lockers and there is no issues the problem is that it hits the pinion when I tighten down the bearing caps.. Jus wondering if others had this issue
01-07-2015, 07:13 AM | #5 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
I have a suggestion. I would love to see some scale hardware with plastic threads for the Exo, Wraith and Yeti.
01-07-2015, 08:42 AM | #6 | |
| Re: Questions, suggestions and contact information Quote:
Could be a few different things... but off the top of my head I know some people have had issues with overtightening bearing caps (in general, not just with our spool). May be some ideas for you here too: vanquish locker with currie axles If that doesn't help, can you submit a ticket on our system? We will of course do everything we can to help!: https://lockeduprc.3dcartstores.com/...tion=contactus When you submit the ticket, please let us know which gears you are running. Last edited by Locked Up; 01-07-2015 at 09:34 AM. | |
01-07-2015, 08:43 AM | #7 |
| Re: Questions, suggestions and contact information |
01-07-2015, 09:13 AM | #8 |
| Re: Questions, suggestions and contact information Nope, you understood perfectly . All of the holes for plastic threaded hardware that holds the cages together are to small for the LURC 3m hardware. Plus we all know that plastic threaded screws hold better in plastic than machine threads. Lockeduprc currently offers hardware to upgrade the axles on a SCX10 which can also be used to upgrade the look of the AR60s but there is nothing available from anyone to replace the plastic threaded screws along the sides and roof lines of the Exo, Wraith or the Deadbolt. I for one would LOVE to see them available to the public. Even if it were just a few stand alone screw options instead of a complete package.
01-07-2015, 05:24 PM | #9 | |
01-07-2015, 06:04 PM | #10 | |
For others reading this: If you have an issue with one of our parts not fitting a stock or another aftermarket part, please do not modify our part until you speak to us. We can't warranty modified parts and there have been a few instances where our parts were just fine but people have modified them trying to fix something. Then they find out the other parts involved were "off" and ours were just fine. For anyone else wondering .... the FI spool is made to NOT be an easy fit for shafts. In order to have a super tight fit with no slop using Axial, RC4WD, VP, etc shafts we slightly undersize the slot. Anyone that has slapped a caliper on all the available shaft tangs out there can tell you each manufacturer sizes things slightly differently. Add in the inherent difference of tolerances between manufacturers and things can quickly go from loose to a force fit. There is some good info in the FI spool thread on getting your shaft into the spool: Locked Up RC - FI Spool Last edited by Locked Up; 01-07-2015 at 06:24 PM. | |
01-08-2015, 04:02 AM | #11 | |
01-08-2015, 04:06 AM | #12 |
for the respect of a great product i will delete my question and if i have any more questions ill email thanks again
01-08-2015, 08:17 AM | #13 | |
No worries! I know you were not bashing. But if you were it would still be OK. It's an open forum and we are happy to help people in any way possible! If you let us know which measurement was different on that service request we'll do what we can to get things working for you. No need to delete anything either. -'Merica! Last edited by Locked Up; 01-08-2015 at 08:21 AM. | |
01-08-2015, 11:04 AM | #14 |
| Re: Questions, suggestions and contact information so feeling determind to use this locker since it needs to be bomb proof for my u4 pro4 rig i dissamble the axle cleaned up the chubs filed the locker inner barrel to clean up the inner locker... reassamble and now every thing went together fine,, feels super smooth and works great the only part that i needed to modifiy was where the outer diameter of the locker when bolted down it would hit the pinion.. i did notice it was alittle thicker then the older style design locker that is in the rear of my currie now im glad i was able to make it work thanks again.. for the support and product i didnt take a pic of the comparisson of the 2 lockers.. but hope this cleared up my issue..,.… |
01-09-2015, 08:49 AM | #15 | |
This is the first I have heard of that measurement as an issue in stock or Currie housings. In the stock housings I have here the pinions actually have a little bit of room (play) to move back and forth when not bolted to a driveshaft. So either your locker was a hair big or the housing was milled a hair to shallow. VP probably milled the housing a hair shallow to remove the play - which is NOT a bad thing. They do a fantastic job of removing play in shafts, housings, etc. BUT ... we do the same. So I could see things overlapping slightly. If anyone else has this issue please let me know and I will make a note on the product page about this. Either way, we will pull an extra hair off the OD of the locker for the next run. Thanks for the feedback! Last edited by Locked Up; 01-09-2015 at 09:05 AM. | |
02-25-2015, 03:51 PM | #16 |
Quarry Creeper Join Date: Jan 2009 Location: longwood, fl
I just wanted to say thank you guys for the exceptional service. When the bad happens people always are first to let everyone know and alot of the times are not told how well they did. I put my order in monday and got it on Wednesday. Thanks guys for the great service
02-28-2015, 05:40 AM | #17 |
Pebble Pounder Join Date: Nov 2013 Location: Bath,ME
I was just wondering why you don't make the ultra rear hubs in the silver finish like the scale pro hubs, and if your going to in the near future. I bought a set of 1.9 rock cutters and agile rings,all the scale hardware and hubs. Just wanted to say they are AMAZING!! Awesome work, I'm on my way to a second set!
03-19-2015, 10:05 AM | #18 | |
For the Ultra we went with a carbon steel because that's whats on a 1:1 and our goal was to be as scale as possible: | |
06-08-2015, 10:48 PM | #19 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I just wanted to say thanks to Locked Up. I had a small issue and Patrick went over and beyond what is expected from a company. Absolutely top notch customer service Thanks |
07-14-2015, 06:31 PM | #20 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Thank you LURC! I received a blem slipper eliminator shaft in an order, contacted CS, and soon after two new shafts showed up in my mailbox! Top notch CS, thanks again LURC! |
Questions, suggestions and contact information - Similar Threads | ||||
Comments, Suggestions and Questions. | Rockpiledriver | RCP Crawlers | 755 | 05-01-2015 04:01 PM |
SORCCA rules comments, suggestions, and questions | Pointman | Scale Comp Rules | 895 | 12-09-2013 01:41 AM |
The crawler store contact and questions | Crossedup | Axial AX-10 Scorpion | 3 | 01-22-2008 05:39 PM |
ultimate hobbies contact information | chupacrawlers | Newbie General | 6 | 08-04-2006 01:04 PM |
