Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: New - Black Ice bushings from Locked Up RC
Old 04-17-2015, 11:47 AM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default New - Black Ice bushings from Locked Up RC
Black Ice is our low weight, high tech solution for those of you that like to yell "Pro 4!" and are constantly thrashing standard bearings.
Our Black Ice bushings are made from a very special Dupont polyimide based material called Vespel. Vespel is a durable, chemically resistant and extremely slippery material. Vespel is graphite-enhanced with low-friction properties and for use with or without lubrication in various applications.
These are available in 5x11x4 and 6x11x4
Thanks for reading.
Locked Up is offline   Reply With Quote
Old 04-17-2015, 01:59 PM   #2
Default Re: New - Black Ice bushings from Locked Up RC
Not to be a PITA but what parts of an Axial rig do these fit? Axle? Knuckle? Trans? I am looking for something that doesn't corrode or fall apart in a week...looks really interesting.
MountainStorm is offline   Reply With Quote
Old 04-17-2015, 04:45 PM   #3
Locked Up's Avatar
No worries.
What I have is they will fit...
5x11x4
SCX10/AX10:
Axle Outer end, Knuckle Outer, Pinions
Wraith:
Axle Outer end, Knuckle Outer, Pinions, Transmission lower outer
Yeti:
Axle Outer end, Knuckle Outer, Pinions, Transmission, transfer Case
TF2:
Front axle, rear axle, transfer case, transmission
Gmade Sawback:
pinion, axle outer, knuckle
Twin hammers:
Pinion
The 6x11x4 are made to fit super 300s
Old 04-18-2015, 04:10 AM   #4
Very impressed i work in the plastic industry and havent heard of this ... id be glad to get some from my rig.... aquired your fairlead today and am very happy with the product .... keep making an amazing product and i will keep buying it.
Thanks guys at locked up
robo4742 is offline   Reply With Quote
New - Black Ice bushings from Locked Up RC - Similar Threads
New - Black Ice bushings from Locked Up RC Locked Up Axles, Trannys, T-case 9 11-01-2016 10:15 AM
Black Ice in July? AddictedtoRC1 Tires and Wheels 11 07-12-2013 05:32 AM
OTTSIX Black Ice Beadlock System Jslick Tires and Wheels 8 06-24-2013 11:01 PM
Novak Ballistic Brushless--black bushing? concretejungle Electronics 2 01-11-2011 08:18 AM
You may edit your posts
