03-17-2017, 10:11 AM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Shim Kit: 5mm ID, 10mm ID With all the various manufacturers of housings, shafts, lockers and gears ... sometimes things don't line up. Some things do play perfectly together but often times you have slop and play between components that can lead to premature failures or unexpected handling characteristics. This shim kit is designed to help remove that slack in multiple axle and differential setups. The smaller shims can help remove play in axle shafts and pinion that ride on 5mm inner diameter bearings. The larger shims work well for differentials and some front knuckle setups that use 10mm inner diameter bearings. Each kit includes 4 shims: 8 x 5 x 0.3mm (2) 13 x 10 x 0.3mm (2) The kit is designed around Axial based axles and differentials, but will fit various applications. Shown on an OT Shaft with bearing and FI Spool for reference (parts not included): Last edited by Locked Up; 03-17-2017 at 10:28 AM. |
Shim Kit: 5mm ID, 10mm ID - Similar Threads | ||||
Diff Shim | Chip73 | Axial Yeti XL | 3 | 05-03-2015 06:23 PM |
Diff Shim Question | FLCErik | Axial Yeti XL | 4 | 12-02-2014 10:13 PM |
Can someone show me or tell me how to Shim the pinion in the diff, thanks | milestone | RC4WD Trail Finder 2 | 12 | 04-02-2014 06:27 AM |
how to shim x factor diff ? | robo-3 | XTM Crawler | 2 | 02-07-2006 07:16 AM |
