03-17-2017, 10:44 AM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| AR60 OT Shafts Very pleased to announce our OT shafts are now available for your Axial AR60! OT Shaft - AR60 straight axle OT shafts offer several improvements over stock AX30776 shafts: 1. Torsional tensile strength rating of over 160in/lbs*. That is over 33% more than a typical stock shaft, which suffers destruction in the 120in/lb range. 2. We thread the end of the shaft several extra turns vs stock. So if you are trying to narrow up your rig with narrow hex hubs and our .185 SLW hubs you can run them with less or no washers behind your wheel nuts. 3. No "hat" near the tangs to more easily pass through axle tubes and past mounting hardware (like Gunnar tubes and CMS kit hardware). Even with these improvements these are a direct replacement requiring little to no modifications to a stock vehicle. You can expect a direct slide in fit with stock lockers, Holmes Hobbies lockers, etc. They will be tight with an FI Spool, because we make FI spools to be tight with everything! Thanks for reading! |
AR60 OT Shafts - Similar Threads | ||||
New Chromoly AR60 Rear Axle Shafts | Harley | Axial Yeti | 13 | 09-07-2016 09:19 PM |
New Chromoly AR60 Rear Axle Shafts | Harley | Axial RR10 Bomber | 23 | 08-25-2016 01:14 PM |
