Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Micro with diffrent lids (mockups)
Old 11-24-2009, 08:36 PM   #1
Default Micro with diffrent lids (mockups)
Here are some photos of my micro with a few different bodies and next to some Mini-Zs for size comparison. I believe im going to try and braze myself a frame and use the GMC truck model but suprisingly I really like the Mini-Z Monster Kyosho Mad Force body on it. It allows for full articulation with zero rubbing. I can actually lower it quite a bit from where it is at in the photos. Let me know what you think. Enjoy :-P
King of Beers is offline   Reply With Quote
Old 11-24-2009, 08:40 PM   #2
Here are some more.
Old 11-24-2009, 09:12 PM   #3
I have crawlers that are way bigger than that! ha ha ha
username is offline   Reply With Quote
Old 11-24-2009, 09:15 PM   #4
Me too
Old 11-24-2009, 09:22 PM   #5
You need to add an o to your signature. "Life is too short"
Ripperfi is offline   Reply With Quote
Old 11-24-2009, 09:24 PM   #6
RPP Hobby's Avatar
We sell a ton of plastic models below are some 1/24 scale yotas we have
RPP Hobby is offline   Reply With Quote
Old 11-24-2009, 09:30 PM   #7
Good catch! I was going to correct you correcting me but I have consulted another source and it seems you are right. I assumed you only use too if you are including something. i.e. I want to come too. My fiance couldnt explain to me why but she "knew it was right". I Googled it and viola! Thanks
Old 11-24-2009, 09:30 PM   #8
here one with a H2 Xmod lid mocked up, seems a tad long
Joeyblaze is offline   Reply With Quote
Old 11-24-2009, 09:31 PM   #9
Have an 88' F-150 single cab long bed?
Old 11-24-2009, 09:33 PM   #10
I cant wait to see some of the sick scaler builds that come out of the micro.
dirtyal is offline   Reply With Quote
Old 11-24-2009, 10:07 PM   #11
Just broke a shock. I only ran one pack through it. Now i have to wait a week or more to get a new part!!!!. Im going to sleep. Damn things are weaker than paperclips.... hmmm maybe i could use a paperclip.... Im still going to sleep.
Old 11-24-2009, 10:17 PM   #12
let me guess you tried to pop it off the ball stud, i just did the same and had to bend my shaft back
Old 11-24-2009, 10:18 PM   #13
I found its easier to unscrew the ball socket from the frame and axle than it is to try and pop the shock off the ball. The shock shafts bend pretty easy and I figure they will break easy too. I put the long micro t shocks on mine and it sits about right now. Good luck!
getbent is offline   Reply With Quote
Old 11-24-2009, 10:19 PM   #14
really i was thinking of doing this as well which color did you use, does it limit articluation
Old 11-24-2009, 10:22 PM   #15
I can't wait to get one.
Brett B. is offline   Reply With Quote
Old 11-24-2009, 10:31 PM   #16
I used 4 of the stock long rear shocks with the stock silver springs. You have to swap the shock caps and bottom mounts, but they attach exactly the same to the micro t shocks, that way you have the shorter shock with crawler ball/stud combo. It limits articulation just a tad, but not really noticable, the lower center of gravity helps a lot and it looks better too.
Sorry to hijak your thread, just tryin to help
Old 11-24-2009, 11:27 PM   #17
Has anyone tried a mini quake body yet? Not the most scale...but might be an interesting fit.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJAG7&P=7
I also wonder how the proline descender body would look on it with some wheel spacers or something. I haven't seen the molds but maybe it would be possible to cut it in a way so that it wouldn't have the comp cut look.
http://www.prolineracing.com/product...dy-192-31.html
ian8811946 is offline   Reply With Quote
Old 11-24-2009, 11:34 PM   #18
both of thoes bodys are 1/18th scale and should be way to big
Old 11-24-2009, 11:38 PM   #19
Yeah but check the widths, 3.5 and 3.88. They might work for more mild builds with the tires under the fenders.
Old 11-24-2009, 11:49 PM   #20
i own both, even tho the widith may be close the body will not work with this scale, the tires are way to smalle for the proportions of the body.
below is a MicroRC and a MQ in the back
