Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: NONSTOPBOOST Micro Madness
Old 11-28-2009, 10:37 AM   #1
Default NONSTOPBOOST Micro Madness
I picked up a BND Micro today...and instantly i realized it sat just way too high...for now i just took off the springs completely...I plan to use a small rubber band to act as an internals once i find just the right size. It lowered the COG a ton and it actually crawls much better...the TT has increased but with some rubbers it will be planted.
I wanted to upgrade something...So since i had a JR 241 MG layin around i threw it in. It has plenty of power and strength now.
Next up is a 2S lipo...gonna look around first for another one but i may just get the losi one.
I moved the battery to the rear axle. It looks like it was designed to go there but was too ugly so they put it up inside.
Major needed upgrade is a new body.. This green just says BLING a bit too much!!
here are some shots...
Yep...Flexin...On a 1.9 Mini Tire...HAHA...These things are tiny!!!
nonstopboost is offline   Reply With Quote
Old 11-28-2009, 10:56 AM   #2
Made a few changes over the last couple days. First i took the foams out of all the tires and re glued them. I put a full ounce of lead pellets in each front tire, which really helps keep the front end down.
I re soldered some more flexible wire from the esc to the motor getting rid of the stiff wire and the unnecessary plug. I plan to rewire the battery wire with more flexible wire also once i pick up a lipo and some micro deans.
I also shortened the wire on the JR 641 so it is just a direct shot.
Then since i just couldn't do the neon green body anymore i picked up a new body and hit it with some black..So far im really liking this toy...Only time will tell what is next to come...
Old 11-28-2009, 02:29 PM   #3
your Micro Crawler looks SWEET. Nice job. For some reason I am really liking the desert truck bodies on these little guys.
Airbornejordan is offline   Reply With Quote
Old 11-28-2009, 04:14 PM   #4
Found a couple little black hair rubber bands that seem to be the perfect size. Now my droop setup is working at it's best.
Old 11-28-2009, 04:38 PM   #5
Any pics of it setup with them, and also just the bands themselves, maybe next to a ruler to see size...or maybe a pic of the package that they came in if ya got it handy?...lookin pimp so far!
VooDuuChild is offline   Reply With Quote
Old 11-28-2009, 05:03 PM   #6
Here are some pics of the bands installed and pics of them alone. My wife had the package of them and said she got the whole package at WalMart for $2. The package contains several different sizes. But i used the largest ones there were. I tried connecting it from the top of the shock to the bottom but it seemed a bit tight. But where i have it hooked now seems to work pretty good. But once you have the bands you can just keep hooking it in random places til it feels right.
