11-27-2009, 03:34 PM | #1 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
| Naz-T's Micro (better than yours)
Well I can't leave anything alone, so before I even charged the battery I started mod'n this little guy. I 1st pulled all the shock springs to lower the stance, I did find some rubber bands that are just the right size to control the suspension I also picked up one of the Losi 180mah LiPo to help lower the CG (it's the lightest battery I can find) This is a must, it runs a lot better on the LiPo. Next I moved the battery to the rear axle I had a JR 241mg servo from my old dig setup so it was a free upgrade (the stock servo actually works really good) It didn't take long for me to realize it needed some weight on the front so I dismounted the tires and removed the foam front and rear then I added some very small lead pellets to the front (shotgun reload) the ESC wires are stiff witch isn't an issue but it bugged me so I proceeded to rewire the entire ESC with some good quality flexible wire (If you aren't a pro at soldering I wouldn't suggest doing this) Topped the wiring off with a Micro Deans I've ran a ton of packs through it with out any issues at all. Thanks Losi Pics Last edited by NaZ-T; 11-27-2009 at 03:37 PM. |
11-27-2009, 03:45 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Exactly How stiff are the 4link joints - IE do the balls need some good teflon to make them articulate better? So is this full droop? |
11-27-2009, 03:59 PM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
Lookin great! What exactly do the rubberbands do? I am a little confused |
11-27-2009, 04:40 PM | #4 |
Newbie Join Date: Apr 2008 Location: bangkok thailand
I like how you managed to take that crappy body and make it fit better. It actually looks cool with the front shocks poking through. So do the shot pellets work well or do the tires not flex as much? How much did you fill the tires? |
11-27-2009, 10:34 PM | #5 |
Rock Stacker Join Date: Jan 2009 Location: nor-cal
After seeing your micro! I have to have one now |
11-27-2009, 11:04 PM | #6 | |
Quarry Creeper Join Date: May 2007 Location: home
Lookin good mike...Now we need to comp these things... Quote:
Im also running the same pellets. I have a full Ounce in each wheel which fills the lower part of the tire. I just removed the foam completely. Since the lead pellets move around it still allows the tire to hook up good. | |
11-27-2009, 11:10 PM | #7 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
it looks great. my only suggestion is to run the battery wires outside the body through the rear shock holes in the body. it allows you to charge the battery without taking off the body. other than its great. makes me wish losi would have sent me the grey instead of the green BND
11-27-2009, 11:38 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: searching
nice work on the body...looks tuff!...I thought about cuttin holes for the frame/shocks to get the body down but wasn't sure if I'd like the look or not...gona do it now! |
11-28-2009, 07:37 AM | #9 | |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
Looks good... I haven't even seen one of those in person. Work has been crazy I haven't even had time to swing by the shop even and fondle one up. | |
11-28-2009, 11:32 PM | #10 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Killer work! body looks tough. Rig looks to be set up nicely!
11-29-2009, 08:03 PM | #11 |
Im also running the same pellets. I have a full Ounce in each wheel which fills the lower part of the tire. I just removed the foam completely. Since the lead pellets move around it still allows the tire to hook up good.[/QUOTE] I just did the same mod, that's 1oz. Per tire as in all 4? After doing this the stock batt won't hardly move the car & my lipo thunder power 480mah 2c causes the slipper to slip at the slightest bind! Plus alot more heat buildup! have you had any similar issues? |
11-29-2009, 08:16 PM | #12 |
I think I have showed half of my family this thread, I am trying to get them to pitch in some cash and get me one for my birthday. Getting one tommorow |
11-29-2009, 08:31 PM | #13 | |
Pebble Pounder Join Date: Nov 2009 Location: The Great Northwest
have you had any similar issues?[/QUOTE] Have you tried just doing the weight in the front tires, then using the battery for the weight out back? It could also be somewhere in the gears not meshing correctly and binding there slightly and the shot was the straw that broke the camels back...? | |
11-29-2009, 08:35 PM | #14 | |
11-29-2009, 10:00 PM | #15 | |
all 4 tires (really helped lower the CoG...LOL!!! I've had no issues w/tranny or worm binding as of yet. I'll empty the rear tires & go from there thanks, Chris | |
11-30-2009, 12:07 AM | #16 |
Quarry Creeper Join Date: Jul 2008 Location: lansing
that truck looks sick...i may have to go that route.
11-30-2009, 03:19 PM | #17 |
Thanks for the compliments guys. and Thanks Boost for answering all the Q's (I really need to get the internet hooked up at home) She is running great I've had the motor get hot but that was after a full pack of hard crawlin, but not to were I was worried about it. Even if I was to fry the motor, it's real cheap. |
