12-10-2009, 10:38 AM | #1 |
Newbie Join Date: Dec 2009 Location: hayward
| 4 Wheel steering.
This is not mine. Just posting it up to share with you folks. Who is going to be the next one with the 4wS mod? http://www.youtube.com/watch?v=6zEQM2L_BFw |
12-10-2009, 10:44 AM | #2 |
RCC Addict Join Date: Jun 2007 Location: MESA
I will definitely be setting one up this way...I want to keep two normal and make one extreme. This is a must do! And really it only cost around $100 for the second rig and look at all the other spare parts you end up with!!! |
12-10-2009, 07:37 PM | #3 |
Rock Stacker Join Date: Dec 2009 Location: maine
Parts are on the way for me, just ordered them last night from HH, it was a toss up, this or a lipo and charger. I will eventually get the lipo. Stock power isn't that bad, run time on the other hand... plus, it will add weight to the rear and I will be able to move the battery from the rear axle to the front axle, were I had it originally.
12-11-2009, 01:00 AM | #4 |
Pebble Pounder Join Date: Nov 2009 Location: The Great Northwest
I have super duper no-speed dial-up. Did he just do front end parts up front with the servo reverse wired for that old school 4ws setup, or did he do a three channel setup for true 4ws? The latter is what I wanna do (as that's what'd be really handy); but I don't know if that's feasable yet due to my lack of being in the hobby since my Traxxas Nitro Rustler was the fastest kid on the block.....I still love my Rustler, it's fast, handles bad and is just all out wicked!
12-11-2009, 02:19 AM | #5 |
Newbie Join Date: Mar 2009 Location: lamar
The guy said he had 2 micros to start with. I`m thinking he pulled the front axle off one and put it on the back of the other. the guy states that the servo in the back is wired backwards then the front.
12-11-2009, 10:31 PM | #6 |
12-12-2009, 12:04 AM | #7 |
So I don't have to bring my multimeter home from work, does anyone know which two wires to swap?
12-12-2009, 02:07 PM | #8 |
Rock Stacker Join Date: Dec 2009 Location: Reno
that was basically the sickest corse ever. i've been thinking of doing this, but i would go 3 channel. what would work better for these things, rear steer or dig? |
12-12-2009, 03:04 PM | #9 |
Rock Crawler Join Date: Aug 2009 Location: Sandy Oregon
The knuckles , servos, and other parts are available at Horizon....should be an easy mod to do I think I'll wait till the extended wheelbase is finished, that will give me more room under the body for the elecs |
12-15-2009, 10:15 PM | #10 |
got all the parts, hooked it up, and as I expected, crabwalk. I then pulled the pins out of the connector and reset them in all the combinations. orange red brown - crabwalk orange brown red - nothing brown red orange - nothing brown orange red -hard left no input straightens out withlfet turn only, right turn, nothing red brown orange - just front steer red orange brown - turns left hard w/out input, tries to turn more (left only) on input. do I need to change some leads inside the servo? thanks for any help. |
12-16-2009, 10:26 AM | #11 |
Newbie Join Date: Nov 2009 Location: Lansing
you cannot change servo direction by changing the servo lead wires around. two of the wires,(red, and brown i think) are for battery voltage, and the last is for signal. You can find servo reversers, which you plug the servo into, or you may be able to go the brutal herbie aproach, and open the servo up, reverse the wires on the servo motor, AND reverse the wiring on the potentiometer. That's if they are not mounted directly to a circuit board.
12-16-2009, 11:22 AM | #12 |
Newbie Join Date: Feb 2008 Location: Tacoma
You want something like this: http://www.horizonhobby.com/Products...ProdID=EXRA325 |
12-16-2009, 01:51 PM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: lansing
but wouldn't that reverse both servos at the same time?
12-16-2009, 07:15 PM | #14 |
12-16-2009, 07:38 PM | #15 | |
12-17-2009, 07:17 AM | #16 |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
so have you guys figured it out yet. my cousin is the one with the crawler your all talking about. and mac is right all we did was reversed the wires inside the servo and added a splitter. he's (my cousin) trying to change it a little and wanting to add a dig unit to it, but dosent want to make any longer, i told him it's going to be pretty hard, and then he's going to buy a dx5 for independant steering, but he need's more cash flow, so good luck on your crawler, and it does make driving over stuff a little harder though.
12-17-2009, 07:25 PM | #17 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
Would you or your cousin be willing to share how he modded the servo?
12-17-2009, 08:10 PM | #18 | |
out of the three wires, cut the tow outside ones and swap there positions. works great! Just need something other than the 3M double sided tape, creates some play in the servo. Last edited by danhikeski; 12-18-2009 at 11:32 AM. Reason: figured it out | |
