Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Beadlocks?
Old 11-24-2009, 08:09 PM   #1
Default Beadlocks?
So do these beadlocks work, or are they like the stock mrc wheels?
if so is there a pvc pipe trick to convert them?
ABOW is offline   Reply With Quote
Old 11-24-2009, 08:12 PM   #2
They do not work. Not sure on a conversion yet. Ive only had mine for about an hour.
King of Beers is offline   Reply With Quote
Old 11-24-2009, 08:14 PM   #3
I havent pulled them apart yet, but I'm sure you could convert just like the mini's. give it time, proline or one of the manufacturers here will come to the rescue in no time!
mysharona is offline   Reply With Quote
Old 11-24-2009, 08:19 PM   #4
I love the look of the losi beadlocks thats the reson i asked
Old 11-25-2009, 05:47 AM   #5
i heard they were glued on but the parts explosion shows they are true beadlocks
low_down is offline   Reply With Quote
Old 11-25-2009, 05:54 AM   #6
On the lookout for Rocks
constantmotion's Avatar
They are glued....no different than the MRCs.
constantmotion is offline   Reply With Quote
Old 11-25-2009, 06:12 AM   #7
so the outer ''beadlock'' is screwed on to the wheel but the tire is just glued onto the rim?
Old 11-25-2009, 07:03 AM   #8
That is correct.
Old 11-25-2009, 07:17 AM   #9
gotcha
Old 11-25-2009, 08:32 AM   #10
The tire is glued, the beadlock is not. The tires pull off really easy, I pulled my front ones apart to wrap solder around the rim to give it weight. It looks like we can convert these to beadlock just like the Mini Crawler. I already put another set of rims and tires on order to experiment with.
Shaun is offline   Reply With Quote
Old 11-25-2009, 10:33 AM   #11
use a metal pipe for wieght pvc too thick maybe....
CM9000 is offline   Reply With Quote
Old 11-25-2009, 07:27 PM   #12
i really like the metal pipe idea
i just took all mine apart and cut notches in the foam, gives a much better footprint now, I also wrapped some thick lead solder around the wheel for some weight
bandit455 is offline   Reply With Quote
Old 11-25-2009, 08:49 PM   #13
Any chance of some pics of your cut foams? Or atleast a better description of what you did (how much you took off). I would like to try this but want to have a plan before i pull mine apart.
Hankinator is offline   Reply With Quote
Old 11-26-2009, 09:04 AM   #14
i took dikes and cut little v's out that went along the foam like 12 or so
and i only went about half way into the foam
Old 11-27-2009, 07:52 AM   #15
It seems as though weight in the wheels is needed for best performance.
I'd love to see some steel wheels made by the aftermarket.
Anyone try filling the tire halfway with metal BBs or tungsten shot?
I'm in Bangkok so I won't get one of these for a few months as the mail is often lost or stolen.
Wish Losi distributed in Thailand.
takman is offline   Reply With Quote
Old 11-27-2009, 09:21 AM   #16
I was thinking of using steel washers as beadlock rings. Drill holes in 'em and screw on.
IssyCrwlr is offline   Reply With Quote
Old 11-27-2009, 09:32 AM   #17
Holdin my 40oz.
Ralphy's Avatar
I like the washer idea, i used to do that on my mrc and it worked good , so I think it should on this little guy. good thinkin!
Ralphy is offline   Reply With Quote
Old 12-05-2009, 04:38 AM   #18
Where are the answers? I'm actually having to post something. :-(
Stupid question on the MINI rim conversion, do the lock rings extend radially past the bead area of the rim? (Which has bigger OD?) I know that you put a piece of pipe in there, and you now have a 4-piece beadlock that actually works, "shut up, just do it, it works", and also that "STFU and search noob!". I don't have a MINI, haven't done a conversion, and the tech in those threads was crap.
The MICRO rim doesn't look promising to me. I mic-ed the Outside Diameters on the rim bead and ring:
1.056" rim
1.047" lockring
We won't get off as easy as the MINI, not really seeing how we can get the bead clamped there with a simple pipe like the bigger one. If it could clamp, it should have already, adding to the OD probably won't help since we're already out past the ring.
MICRO RockClaw Tire bead width lets call about 0.060" for a little squish
Rim bead width 0.080"
Tire bead clamp area lets call 0.040 outside (to sidewall), maybe 0.070 inside
Rim bead seat depth 0.035"
If we file the rim at mating surfaces of the ring, it would narrow the bead seat and we should be able to pinch the bead.
If we cut down the rims bead we might be able to get some kind of pipe on the rims that would actually give us clamping surface under the rings?
Or maybe we can find a pipe that could work for the extra bead clamping the rim is missing between 1.056" - 1.091" , but would that work with the 0.020" gap between bead and rings?
Am I just missing the obvious?
frizzen is offline   Reply With Quote
Old 12-05-2009, 09:13 AM   #19
My thoughs are
take a copper pipe (2in) and cut and shut it to fit snug aroud the rim.
after cuting, you shut it with torch and soder.
Tape could also work!
Old 12-18-2009, 04:12 AM   #20
Exclamation
I'm wrong! It works!!!
Micro PVC Beadlock Mod
