12-25-2009, 06:41 PM | #1 |
Newbie Join Date: Apr 2008 Location: country
| motor dont stop
why is it when i turn off the radio first the motor runs and the wheels turn to the right? we have been running it all day and it just started doing this. when i turn the radio back on it takes a minute for it to stop and able to run with the radio.thanks in advance
12-25-2009, 06:43 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I am not familiar with 2.4 setups, but some FM setups do this as well. When you turn your Tx back on, it takes a second to bind the signal, then the Tx is sending neutral signals again, so it stops. |
12-25-2009, 07:56 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: Sandy Oregon
Always turn off the truck first, then the radio.....turning off the radio first cuts the signal to the truck and radio "Noise" from your surroundings can cause the truck to turn or run on it's own accord. Also when the truck is not being run...always unplug the battery.
12-26-2009, 08:00 AM | #4 | |
Rock Crawler Join Date: Dec 2005 Location: houston
12-26-2009, 09:14 AM | #5 |
Rock Stacker Join Date: Dec 2008 Location: mission viejo
BIND again.. reciver will reset
12-26-2009, 09:43 AM | #6 | |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
12-26-2009, 10:54 PM | #7 |
Newbie Join Date: Jun 2009 Location: arvada
you have to bind the truck and radio again. when you bind these this is your failsafe setting
12-27-2009, 02:08 PM | #8 |
thanks for the help the rebinding worked.
12-27-2009, 02:15 PM | #9 | |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
Oh... you should always turn your truck off first then the transmitter. | |
