12-28-2009, 02:38 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Reno
| Is the esc programmable
I bought a bnd version and bound it to my futaba 3pk. I had to max out both the subtrim and the normal trim forward to get it to sort of stay still. It still has a tendency to want to reverse at neutral throttle. Does anyone know if the esc can be programmed? The manual said nothing about it.
12-28-2009, 03:24 PM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Sounds you need to calibrate the esc to the radio, set your end points to 100+ % and trims to zero.Then follow the calibration directions in the manual.
12-28-2009, 07:15 PM | #3 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
I didn't think the BND would bind to the Futaba system and would only bind to Spektrum radio's.
12-28-2009, 11:12 PM | #4 |
Rock Stacker Join Date: Sep 2004
^^^ I'm guessing he has a spektrum module in his 3pk.
12-29-2009, 02:47 AM | #5 |
there are no calibration instructions in the manual. i do have other electric cars, so i know how the calibration process goes, i just don't know how to get this esc into calibration mode. yes, i do have a spektrum module |
12-29-2009, 07:12 AM | #6 |
Have you tried calling Losi for help?
01-02-2010, 10:20 PM | #7 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
I'm having the same issues with the same radio setup, hope someone figures it out!:?
01-03-2010, 12:26 AM | #8 |
Rock Stacker Join Date: Dec 2008 Location: mission viejo
try everything on middle position and BIND again...
01-03-2010, 01:34 PM | #9 |
Actully, I reversed the motor wires. centered everything again, set THR to normal not reverse (I had to reverse THR when I Binded for the first time because it wouldn't stop turning in reverse) everything seems fine now, everything centered and I can control the motor speed better now! |
01-04-2010, 02:20 AM | #10 |
i had all the trims and subtrims set neutral the first time. i'll give it a try again though.
