![]() | #41 |
Rock Stacker Join Date: Aug 2008 Location: cincinnati
this thing is looking better all the time, my favorite micro by far
![]() | #42 |
Pebble Pounder Join Date: Sep 2009 Location: Michigan
thanks, buddy ![]() |
![]() | #43 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Lookin good bud, like the rear leafs ![]() You should check out my dually build. |
![]() | #44 |
Quarry Creeper Join Date: Dec 2009 Location: Long Island
Looks good so far David. Just so you know the idea for front leafs will have to be ditched on my Silverado, I tried pretty much every steering setup possible with zero positive results...:( Any more pics on this thing or did it contribute to the tow rig?
![]() | #45 |
I borrowed the front axle. ![]() ![]() |
![]() | #46 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
Digging up an oldy but didn't see an answer given. What is the motor you are running?
![]() | #47 |
the motor used is a GWS cn12-rxc
![]() | #48 |
Thanks. Being longer I assume it has much more torque than stock. In the pics it shows you running the stock battery but I looked that motor up and it says 6-7.2V in the specs. Does it run fine on the lower voltage for you? I run 1S lipos and don't really want to buy more batteries.
![]() | #49 |
this motor is slower than stock on the high end. with the stock battery it has lots of torque. it gets hot too so if you have room for a heat sink it may be a good idea
![]() | #50 | |
I wanna be Dave ![]() Join Date: Feb 2007 Location: South FL
| ![]() Quote:
I would imagine if you want more torque a better way is a motor with a bigger can? Just a guess | |
![]() | #51 | |
| ![]() Quote:
![]() | #52 |
Rock Stacker Join Date: Aug 2010 Location: United States
this is awesome! my micro has an f-150 body on it now, but soon it will have a land rover body or a dodge ram body!
