ford F350 4 Attachment(s) Thought I would try building a dually... ENJOY"thumbsup" |
That is sick! Any body off shots? How did you mount the duallies? |
5 Attachment(s) the dually wheels are made by cutting the center out of one rim, then cutting that rim in half, then gluing those halfs to the sides of a normal rim. didn't even take the beadlock rings off. but i did remove the screws and glue the ring to the rim. the servo is glued to the body. not the best idea when it comes to needing a new servo but it does keep the steering geometry better. the drive shaft in the front is stock. the rear is made out of miniquake axles and has a midship bearing. the shocks are from a mirco t, i enlarged the endcap holes to fit the stock screw more losely as to prevent binding. thanks for looking:shock: |
Omg! Please elaborate on the build! "thumbsup" |
Sweeeeeet. Looks like those trucks they use in "redneck" pull contests (usually at mud-runnin comps)! Now you need to make another and have a pull-off!!! |
Very nice..... good idea on the dually rims. What made you use dual shocks in the rear though? It looks great, just curious...... |
a real redneck puller would have 3 axles!!!! |
just looks cool, really the body was to heavy for the micro t springs. in the front i was able to squeeze the stock crawler springs onto the micro t shocks. works the same with less travel. |
looks good, what did you use to support the second rear driveshaft? Is that a bearing and small shaft? |
Yes, there is a bearing in the center. The smaller shaft is the male half of the stock shaft glued, into the female half of a miniquake axle. (mouth full) Because the shaft never needs to telescope it was OK to glue to length. The longer telescoping shaft is a complete MQ axle. The yokes on the MQ axles are hollow so I used a screw to clamp a bearing between them. Then clamped the bearing to the crossmemder on the chassy.:shock: I'm sorry I dont have a photo from assembly:cry: |
Other than being pretty bitchin, all I wanna know is... What Geffen servo is that? |
You need to get another micro and make that a trail rig and use the ford as your towing vehicle. |
good guess tyhodge07, it is a hitec i had in a heli. the sticker is gone from trimming the case. also the wire is a new longer one i need to reach the esc in the back of the cab |
one of the best build I have seen so far. Keep it up!! |
wow i really want to build one of these really bad.....but i want to make it an 01 4 door long bed if you got any helpful tips for me pm me please do it and where do most people get your model body from? |
5 Attachment(s) well its been awhile, i have updates on this rig. i put in the tail lights in and new front bumper. i also thought i would try leaf springs in the back. also beefed up the frame."thumbsup" |
It just gets cooler and cooler! |
