01-07-2010, 08:18 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: USA
| New Micro Owner
Hey everyone, I just picked up my micro and love it already. I put 1 oz BB's in each front tire, removed the springs, and relocated the battery so far. I have a quick question though...sometimes when I am going down hills the back axle gets stuck up in the air and won't drop back down to the ground and I end up tipping a lot because of this. It's almost like the rear tires aren't heavy enough to force them back to the ground so it just stays articulated in mid air. Anyone else having this problem? I am thinking of adding some weight to the rear but I don't want to upset the nice balance I have right now. Thanks. |
01-07-2010, 08:25 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
try adding a little weight to the tires dont need alot but a little might just do the trick, everything needs a little fine tunning lol
01-07-2010, 10:41 PM | #3 |
I wanna be Dave Join Date: Sep 2004
a little weight on the rear axle will help. just like adding weight to the front to help with up hill climbs,adding some to the rear helps with descents.
01-08-2010, 12:59 AM | #4 |
Rock Stacker Join Date: Dec 2009 Location: Reno
try putting you battery on the rear axle, seems to help a bit.
01-08-2010, 02:46 AM | #5 |
Pebble Pounder Join Date: Dec 2004 Location: DFW
01-08-2010, 09:16 AM | #6 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
| 3/8" lock washers--closed and reamed out just a hair in the inside--slip right over the back and inside of the wheel, under the bead lock ring. They'll only give you abut 2.5grams/each, but it's enough to note a small difference and shouldn't combat that 1oz you have up front.
