01-08-2010, 10:38 PM | #1 |
Newbie Join Date: Dec 2009 Location: North of Waterloo
| Micro Ranks
As in joined them! Got a black one tonight. Charging it up as we speak. Going to do some reading so I can get started modding.:-P
01-09-2010, 09:13 AM | #2 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
These things are a blast! I got mines and so far the only thing I have done is take the springs off, though I haven't had much chance to test it that way.
01-09-2010, 11:47 AM | #3 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
Lipo's guys they make all the difference
01-09-2010, 06:31 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
these lil guys are great. i cut 4 coils off the springs, reversed the tranny, lipo on the rear axle, and micro deans so far. that little made a huge difference! like you said, read these these threads. plenty of knowledge and sick rigs to be found!!!! have fun!!!!!!! |
01-09-2010, 08:10 PM | #5 |
Took the foams out and put the bat on the servo. What does cutting the springs do? I can't wait until the aftermarket gets ahold of this thing.
01-09-2010, 08:12 PM | #6 |
cut springs = lower center of gravity, and semi droop to improve its handling on the rocks
01-09-2010, 08:29 PM | #7 |
You will love it! So far I have: BWD wheel weight kit relocated battery and esc to axles removed internal plastics cut the original battery holder down to use as a chassis brace to reduce flex of having taken plastics out. (coming soon BWD Wedge) droop using mirco t rears stretched over the shock cap and ball cup as return springs, red (medium) rear and white (soft) front, Inverted shocks lowering CoG extended bent lower links, extended upper links Lowered upper shock mounting point to old internal plastics mount, lower CoG lipo flipped tranny shifting weight forward Hacked the body to allow droop clearance of esc on front axle. Cut windows out of the body (weight redux?) lol just for fun. hs-65 servo - ridiculous steering power! |
