01-13-2010, 04:55 PM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: The sticks
| Servo size question.
Im trying to plan a build for a micro high roller, and im very new to micros and not to sure about the servo i need. Ebay has some the say they fit but they are 30 bucks i found some cheaper with measurements, but i dont know the measeurements of the losi servos so i was hoping someone in here could help. Thanks! |
01-14-2010, 03:32 PM | #2 |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
Being the Hitec HS 55 is a drop in fit, you could do a search and find the specs on it. http://www.rctoys.com/pdf/hitec-servos/HIT-HS55.pdf |
01-14-2010, 04:01 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: Sandy Oregon
stock servo is 22mm wide 26mm long 6mm thick
02-09-2011, 10:47 AM | #4 |
Newbie Join Date: Oct 2010 Location: Nova Scotia, Canada
I sucesfully installed the HS55 in my micro high roller. Had to modify the servo, chassis to accept the Hs so it's not exactly drop in but it can be done. I mated it with the micro rock crawler B'nD esc/receiver combo. I fired it up and binded it to my DX3R. There was also a mod i had to do to the servo saver as well which was a little bit of a challange. Worth it though - smooth and wicked range . Need to set a delay between forward and reverse though lololol. If you need pics let me know. Thanks, B Last edited by Bernman; 02-09-2011 at 11:07 AM. |
02-09-2011, 07:33 PM | #5 |
Newbie Join Date: Jan 2011 Location: Ontario, Canada
Search MG90S on ebay... You'll find awesome package deals!! All you have to do is drill holes to make it work on the micro (there's two mounting holes on them, but we need 4 holes for our micros). All metal and more torque! I'm very happy with mine. But keep in mind that the more powerful servo drains the battery significantly faster. I did not expect that.
