Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: How are you guys doing leafs?
Old 02-19-2010, 08:13 PM   #1
Default How are you guys doing leafs?
Like what material that is readily available are you using to make your leaf springs etc... I'm trying to go for a more scale look but the problem is my shock mounting location won't allow the axles to go any lower on the truck in so in full droop, it sits more at a lifted truck height rather than scaler height. I can partially lower the front end down but not the rear. I'm willing to fabricate up some leafs or buy them but then what are you guys doing for the shackles, also? Thanks in advance!
-Ian
Stampedekid is offline   Reply With Quote
Old 02-20-2010, 01:20 AM   #2
i made my leaf springs from an old HPI nitro pull starter. the hard part is mounting them to the axle. i tried drilling a hole in them with a drill press with no luck. then i tried filing a tig welder tip to a point but that blasted the spring in half. so i used tag wire from work and made tiny super small u-bolts. works like a charm. for shackles i used 0.060" styrine. also works like a charm. hope this helps
chameleonkid is offline   Reply With Quote
Old 02-20-2010, 06:22 AM   #3
I used the same nitro pull start spring.
I did drill a hole thru the center of the sping, and drilled a hole thru the axle c, and bolted it down.
For shackles, I used brass.... a lot harder to work with, but sooooo worth it.
soundcolor is offline   Reply With Quote
Old 02-20-2010, 11:55 AM   #4
Hmm anyone mind making up a set? I've got no access to styrene which is why I had to use aluminum in my Scaler build. Yeah I know it sucks but it seems no stores here have one, even the home depot that is literally 2 minutes walking distance. I was told thin aluminum sheets cut to the right size would work too?
Old 02-20-2010, 07:32 PM   #5
aluminum isn't going to work. It is a material that will bend and not "spring" back. you need to use a metal that is heat treated. order a starter for any nitro engine.
danhikeski is offline   Reply With Quote
Old 02-21-2010, 08:51 PM   #6
Oh ok. I may end up not doing it, I got the front drooped to the right height(though it does rub a little, have to work that out) and the rear I'm probably just going to do a Bed Cage and mount it off that.
Old 03-22-2010, 11:18 PM   #7
Talking here is my set up
Here is what i am running but rcbros. has a good kit from what i hear. I used all tamiya parts for my truck tell me what you think. wanted it pretty scale so I went hand bros in front with links and leafs in rear like a real bronco.
IbeenHalved is offline   Reply With Quote
Old 03-23-2010, 03:22 PM   #8
Just get the Blade SMC chassis, its already setup for and comes with leafs!
KRAWLR4life is offline   Reply With Quote
Old 03-23-2010, 04:23 PM   #9
Too bad that chassis still doesn't really exist though!
SLODRIVE is offline   Reply With Quote
Old 03-23-2010, 06:44 PM   #10
Thats funny.. Im looking at mine right now.. This was taken at RCX 2010 this past weekend!
ITS COMING!!!
Old 03-23-2010, 07:37 PM   #11
Actually guys its quite alright, and I couldn't run Blade's chassis anyway, it would be WAY too short for this scaler Chameleonkid made them up to my dimensions and should be arriving in a box(or padded/bubble wrap filled envelope) sometime this week. The shackles, well I'll have to figure that out.. and Ibeenhalved, you do realize this is on a Micro scale, right?
Old 03-24-2010, 01:42 AM   #12
That's right chameleonkid made some
Old 03-24-2010, 05:05 PM   #13
Yup! Still haven't gotten them yet but oh well I suck at waiting so yeah
Old 03-24-2010, 10:13 PM   #14
They're on the way! pics of just before they were mailed.
Old 03-25-2010, 06:50 PM   #15
Thanks a ton man. So when did they ship out?
Old 04-08-2010, 07:49 AM   #16
Nice looking springs.
Is that some small wire on there holding the leafs together? Was also wondering how many sets of springs can be made from one pull starter?
rcmaineiac is offline   Reply With Quote
Old 04-08-2010, 09:04 AM   #17
depends on how long the springs are, whether or not you have multiple leafs and the amount of arch in the springs themselves...
I would say a full set or two would be easy to get... I got 3 full sets out of my pull start
Old 04-08-2010, 09:32 AM   #18
I would agree. It all depends on how you make them... but about 2 or 3 sets. Those leafs are made out of an HPI k4.6 nitrostar pull start
Old 04-08-2010, 05:21 PM   #19
I've actually been thinking..
You know those laundry baskets you can get at places such as walmart, walgreens etc..? Well we've had them in my house(mom likes them because they fold and are convenient) and well a few are falling apart, but I noticed they might be good to make leaf springs if anyone needs visual reference, I'll get pics. By the way, David I got the rears mounted but it was hard because I had many holes drilled from when it was shock sprung and during "prototyping" back when I had no clue what I was doing in January. So used some modeling putty to fill in those and going to re-do it, right now it looks completely unrealistic but within a few hours, that should change. Hopefully I can get the fronts mounted tomorrow and be all good to go ~Stay tuned~
Ian
Old 04-09-2010, 08:57 AM   #20
my problem is how are you guys mounting them can someone put a picture up here to show me how to make it work...,.
ax10rtrmaster is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
