07-27-2010, 08:01 AM | #1 |
Newbie Join Date: Mar 2010 Location: UK
| 2s lipo
Hi - I just want to 100% clarify the use of 2s lipo's in Micro's - I don't want to buy some & fry my Son's pride-n-joy. Can I use a 2s lipo with STOCK RECEIVER, ESC, MOTOR & SERVO ? I read lots of examples of people buying them but it's not always obvious / easy to check if they're using stock kit. Cheers - A |
07-27-2010, 08:03 AM | #2 |
Mine works perfectly on a 2S lipo. The stock ESC even has a low voltage cutoff set for 6.4V....
07-27-2010, 08:11 AM | #3 |
Quarry Creeper Join Date: Apr 2006 Location: the creek
yes, 2s will work, and as mentioned, has the low voltage cut off!
07-27-2010, 08:41 AM | #4 |
Guys - that's great news thanks - He was a bit disappointed over the <10 minute run time with the stock battery I've a lipo charger so should be good to go |
07-27-2010, 09:26 AM | #5 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
I run the losi 2s 180mah lipos. It comes with an "hour" charger and it works great for $50 @ LHS
07-27-2010, 09:35 AM | #6 |
I run these lipos on my micro: http://krawlerhobbies.1freecart.com/...micro-lipo.htm And they are great! The last about 40 minutes and the wheelspeed is perfect! You will have to change your plug into the ESC (either change to JST on the ESC or change the battery to that losi plug). They fit well too: |
07-27-2010, 09:56 AM | #7 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
I have a couple of the same that JeremyH is using... I like them better than the Losi 180mah. Li-po is the answer to these micro's. |
07-27-2010, 11:11 AM | #8 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
07-28-2010, 03:18 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
I run 360 mah ( rhino ) and 240 mah ( hyperion ) and even tho i have not timed my runs i can say that all is well regarding run-times I prefer the hyperions as they dont have a balancer plug, and the 360 mha ones are the biggest ones i have seen mounted on the rear axle. I even have a couple of 1s 240 mah hyperions,but thats damm slow and stall when a little "load" is applied. I contemplate installing the biggest spur i can get to try and ease a little up on the trottle control with 2 s lipos. Everything was stock when i startes using 2 s lipos,and it still is aside from the sweet hitec steering servo i got to replace the dead stock servo ( killed plastic gears in it ) |
07-29-2010, 07:43 AM | #10 |
My run times are bout 20-30min id say, haven't actually timed it though and the recharge time is no longer than a hour
07-31-2010, 10:20 AM | #11 |
Newbie Join Date: Dec 2009 Location: Southern NH
| How did you determine 6.4V cutoff? That sounds right, but the manual doesn't explicitly state there is a LiPo cutoff AFAIK. I searched for just about everything I could think of within the PDF and found no references. Is this an undocumented feature?
07-31-2010, 02:54 PM | #12 |
Quarry Creeper Join Date: Dec 2009 Location: Long Island
I use the Losi 300mAh 2S in my micro Silverado Scaler(Micro Rock Crawler based), originally used in my BL Micro DT which gets about 25+ min run times. The Silverado usually gets 20-25 minute run times but for a micro, its 9.1" long and heavy for a micro so yeah. Would never run NiMH in one of these little guys ever again after using LiPo
07-31-2010, 03:50 PM | #13 |
Rock Stacker Join Date: Feb 2010 Location: Portland,OR
I use 6 AAA rechargeable 900mAh batts that i had just laying around the house. I've run them for over an hour but something on the truck allways breaks before the batts die.
08-02-2010, 01:40 AM | #14 |
Newbie Join Date: May 2009 Location: nsw-australia
mines still running sweet all stock but with a 2s lipo- love my micro!
