09-03-2010, 07:29 PM | #1 |
Newbie Join Date: Jul 2010 Location: Parker, Co.
| Servo twitch.
Done some searching with minimal success. The twitching with my steering servo has gotten to the point of undriveability. Solutions? I have read of re-wiring, but what do y'all think about the replacement of key electronics? Links appreciated. Thanks. |
09-03-2010, 07:41 PM | #2 |
Rock Stacker Join Date: Aug 2010 Location: Grafton, NH
I know on one of my crawler (1/10th) it was low batts in the radio, and another rig it was a dieing one hope you figure it out |
09-07-2010, 09:31 AM | #3 |
Newbie Join Date: Oct 2009 Location: Lansing
I had the twitchy servo problem... at first, I got it to quit by replacing the batteries in the transmitter. Then it came back... replaced batteries again, but this time it didn't fix the problem. Checked the batteries with a meter and all were good. I check all my wiring, still had twitch. I replaced the servo, and the problem went away. I went with the HS-55 servo, but it is not a direct bolt-in, so be prepared to modify if you go that route. HTH, Darsix |
09-09-2010, 05:33 PM | #4 |
Newbie Join Date: Nov 2009 Location: moon
personaly i went with the hitc hs65mg it was only abit snug on the servo plate but otherwise it fit just fine
09-09-2010, 05:47 PM | #5 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
Would this one work too? Its pretty inexpensive http://www3.towerhobbies.com/cgi-bin...2&I=LXNCV6&P=K |
