Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Home made micro tires
Old 01-29-2011, 10:45 AM   #1
Default Home made micro tires
hey guys..decided to make my own tires for the micro crawler because i wasent happy with what was out there for my rig...
cost me $47cad at my LHS and 3 nights after work...the results are insane compared to stock or the rc4wd tires
kgraham204 is offline   Reply With Quote
Old 01-29-2011, 10:46 AM   #2
Old 01-29-2011, 10:47 AM   #3
i also made wheel wideners for it by cuting the hubs from the stock wheels and gluing them to the rear of the new ones
Old 01-29-2011, 11:17 AM   #4
NO !! i was just about to order stuff to do this lol.
They look great, how tall did yours come out ?
ScalerLover is offline   Reply With Quote
Old 01-29-2011, 01:25 PM   #5
Originally Posted by scalerlover View Post
they look great, how tall did yours come out ?
x2?
T-buck is offline   Reply With Quote
Old 01-29-2011, 02:38 PM   #6
What tires are they? Did you just slip them over the stock tires and glue them, or just use the sidewalls from the original tires?
InFlames is offline   Reply With Quote
Old 01-29-2011, 03:04 PM   #7
Location: Taylors Falls just hanging with the MNRCRC crew.
I knew it was just a matter of time and we'd start seeing the micro cut and shuts. I've been thinking about a Losi Eclipse red compound on Losi or RC4WD sidewall.
Nice work.
Stormin2u is offline   Reply With Quote
Old 01-29-2011, 03:09 PM   #8
that look crazy. I like that. do you have any steering problems after doing that? what tires are those and how is it done.
crawlerknownothing is offline   Reply With Quote
Old 01-29-2011, 04:01 PM   #9
I have a set of over sized tires and without wideners your steering will be reduced.
Old 01-29-2011, 07:53 PM   #10
Those tires look badass. Good work on those. Have you thought about cutting the length of the pins down at all? Wonder how they would do about half of that length.
TruckerBrad is offline   Reply With Quote
Old 01-30-2011, 01:01 PM   #11
The overall height of the tires is 60mm and yes i widened all 4 corners and i will be adding one more set of wideners to the front of it....the tires are losi mini step pins that i narrowed and used the stock sidewalls cut and fit to the larger beads of the mini step pins... i also added 2x wraps of 7gram lead pieces cut in half...(3.5grm peices) the results are insane climbing compared to any tire ive tried yet....i make wideners from cutting hubs from other rims and glue them in the back of another rim and drill trough the face to get the nut on..
Old 01-30-2011, 01:03 PM   #12
yes but i havent thought of a design yet...was hoping to get this ball rolling and see what others come up with
Old 01-30-2011, 01:12 PM   #13
well after some testing at our local track im in need of some gearing down....i was expecting it though...lol..so i got some micro t gears that im gonna try out.....probally have to cut a new engine plate for it to get the gearing i need
Old 02-06-2011, 01:23 PM   #14
so i added a 56t spur gear and a 10t pinion and thats the ticket to these tires . now i got to cut them down a little so they grab a bit better
Old 02-07-2011, 01:01 PM   #15
Damn good work sir.
BEELZEBOB is offline   Reply With Quote
Old 02-07-2011, 06:09 PM   #16
rik
damn, these look good. i give this ,, nice work...
rik is offline   Reply With Quote
