Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Street's t4r build(going IFS)
Old 01-21-2012, 07:08 PM   #81
Midlife Crisis's Avatar
Default Re: Street's t4r build(going IFS)
Pretty awesome frontend you have so far. How will you be addressing the steering? T or SCT draglink maybe? Ball and socket tie rods?
Also, what limits your droop? Will the dogbone limit it?
Midlife Crisis is offline   Reply With Quote
Old 01-21-2012, 07:46 PM   #82
Thanks MC. I don't think I'll be using anything like the T or SCT draglinks. Will most likely be some form of ball and socket tie rods.
As for droop. Currently the dogbones are limiting it but I have started making some pretty scale shocks from the micro-t shocks I bought. They will be what limits the droop in the end. one end is going to be solid mounted with rubber bushings and the other will mount the stock way that the T shocks connect.
StreetKill831 is offline   Reply With Quote
Old 01-21-2012, 08:15 PM   #83
I wonder if a servo horn could be used to mount 2 ballstuds and them go straight to the steering arms, eliminating a draglink altogether. Are they out front or in the rear on your setup? I can't tell from the pics.
Old 01-21-2012, 08:22 PM   #84
They are in the rear. That's pretty much what I'll be trying to do. I just ordered the motors as well as a new aluminum servo horn.
Old 01-21-2012, 08:43 PM   #85
Sweet
I'm anxious to how exactly the speeds are going to sync up. Have you figured out each diff's gearing exactly? I might have missed it.
Old 01-22-2012, 06:21 AM   #86
Sweet
SCT diff is 2.53:1, losi axle is 12:1.
With the motors it isn't going to be perfect but it should be pretty close.
...I hope. I'm pretty anxious too.
Old 01-22-2012, 11:24 AM   #87
Another trick done to the micro cups is to harden them ... heat them up cherry red then dip into motor oil.
It makes them last longer.
Otherwise they'll wallow out in short order ... especially at those operating angles.
Sent from my Desire HD using Tapatalk
Rockfrog is offline   Reply With Quote
Old 01-23-2012, 05:52 PM   #88
Decided to add fender flares. Can't decide if I should paint them black or match them to the body.
Old 01-27-2012, 07:05 AM   #89
Power plants mounted.
Old 01-27-2012, 07:47 AM   #90
No more Losi trans huh? What motors are those?
8695Beaters is offline   Reply With Quote
Old 01-27-2012, 07:54 AM   #91
Yep They are micro geared motors. Front is 56:1 ratio at 480rpm and the rear is 50:1 ratio at 400rpm.
Old 01-28-2012, 08:47 AM   #92
Speed looks good. Won't know for sure until I can flip it and drive it.
Old 02-08-2012, 09:52 AM   #93
Here is a video showing how things are going. I ended up getting a different motor for the front and now the speeds match up almost perfect. Pretty damn slow but I like it
Going to be adding shocks up front to limit droop as well as locking the front differential.
Anyone know how to make the Aoshima swampers softer? Or know of another tire about the same size that is softer and grips better?
Old 02-08-2012, 11:24 AM   #94
Try RC4WD's Boggers. They should work pretty good, softer and about the same height. You could also try some traction compound.
Old 02-08-2012, 07:47 PM   #95
Aren't those the same height as the crushers and their other tires? Traction compound?
Edit*
Yep same size, much to large. The aoshima super swampers are just about the perfect size. The compound just kind of sucks..
Old 02-08-2012, 07:53 PM   #96
Traction compound will soften the tire a bit. You can also try boiling them. I use Parma Ground Effects on my 1/12 car. It softens plastics, so make sure you don't get any on the body. let it dry and it should soften the tires some.
