03-31-2011, 08:02 PM | #1 |
Newbie Join Date: Mar 2011 Location: mile high city
| motor wires
Can I shorten the motor wires on a sidwinder esc for a 2000kv motor conversion? ... I'm not going to shorten the wires from the can ...
03-31-2011, 09:01 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
isnt it as easy as soldering new connections on cut shorter wire? not sure what your needs are but i guess tying them out of the way wont work. @ 2000kv I guess you are using the Hextronix outrunner. considering how cheap those are I would rather cut those wires short, you need to add connectors to them any way |
03-31-2011, 09:27 PM | #3 |
Some told me if you shortin the wires it will change the wind of the motor ... I'm not really sure .. I figured someone would know for sure .. my plan is to do .8mm micro connectors like creepyg did . But I wanna put them right on the esc . Or 3-4 mm off of it from the stock wires ..
03-31-2011, 09:58 PM | #4 |
Im no motor expert but if it changes anything it wont be the physical wind of the motor. the "wind" from what i understand is how many times you wind the stator in the motor. again at $6 or $7 i would rather cut the motor wires. I believe creepy G or someone else cut them down & folded them over so they would fit better in crimp connectors without any issues.
04-01-2011, 10:20 AM | #5 |
Any one else have any input on this ? I ready to wire this turd and don't want to f it up
