Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Wicked New Chassis for the losi Micro
Old 05-11-2011, 07:45 AM   #21
BLADE's Avatar
Originally Posted by anthony View Post
Blade can you run with the motor forward?
Anthony
Not on the Ridgeback but I will double check to make sure.
Blade
BLADE is offline   Reply With Quote
Old 05-11-2011, 11:52 AM   #22
BLADE's Avatar
Ok I got some parts made for the Ridgeback TC micro
I am experimenting with some ideas so will see how it turns out.
Here is a pic of the Panels
Old 05-16-2011, 01:22 AM   #23
Soooo sick, I'm gonna have to get this lol. Any pics of it fully assembled? Maybe some action shots?
humanmachinehead is offline   Reply With Quote
Old 05-16-2011, 02:15 AM   #24
I pre-ordered one.
Evilinside is offline   Reply With Quote
Old 05-16-2011, 07:44 AM   #25
BLADE's Avatar
I do have some pics and video of it I will get that posted soon. I will have some more buld pics in the next couple days as well.
Also pre orders will start shipping this week. Thanks for all your support guys.
Blade
Old 05-21-2011, 10:03 PM   #26
the wait for pics is killing me haha
Old 05-21-2011, 11:04 PM   #27
BLADE's Avatar
Sorry guys, been real busy I will get some pics up soon
Blade
Old 05-21-2011, 11:45 PM   #28
pppppppllllllllllllzzzzzzzzzzzzz get the pics up soon
i luv duct tape is offline   Reply With Quote
Old 05-22-2011, 01:02 AM   #29
Cool
My Ridgeback is on it's way, and I think it will arrive someday next week. And if the converting from TMC to RTC goes easy, I'm able to post some build pics almost instantly after I get my hands on the new chassis!
Paul4x4 is offline   Reply With Quote
Old 05-22-2011, 09:46 AM   #30
Mine was shipped, will have a build thread up soon.
Old 05-22-2011, 10:21 AM   #31
cant wait to see a build on this little beast.
Southern_racer is offline   Reply With Quote
Old 05-22-2011, 10:55 AM   #32
order shipped, build thread soon to follow!!!!!
stroker613 is offline   Reply With Quote
Old 05-23-2011, 07:35 PM   #33
BLADE's Avatar
Here are some more build pics
In this pic you can see how I mounted the rear upper links
on the rear plate by drilling some holes and mounting the ball ends
I also did this so that my links could be mounted on the inside of the plates
I also got the best results with the longer wheel base by repositioning
the front upper links by making a custom upper link mount this will be
available soon for those of you who would like to use it.
This also made it so I could mount the links on the inside of the plates pics
below.
Here is a pic of the extended drive lines in the picture you
can also see I made some custom Link shock mounts I did this because do
to extending the wheel base it put to much stress on the shock ends.
You can see the panels mounted and the roof panel. To mount
the roof panel you have to atach one side and heat it up with a blow
dryer or something similar and bend it over the roll bars but make sure not
to over heat the plastic or it will be ruined.
Old 05-23-2011, 10:06 PM   #34
What did putting your rear upper links like that do for you? The limiting articulation factor that I've had on these rock crawlers has been the lower links, so I'm curious...
Old 05-23-2011, 10:13 PM   #35
BLADE's Avatar
When I stretched it to 5.5" wheel base and tried to use the links the same as stock the axles swayed back and forth. So by putting the links
like I did they stayed solid.
Blade
Old 05-23-2011, 11:19 PM   #36
Oh I see.
Old 05-24-2011, 01:08 AM   #37
Looks goodI'm experimenting with the upper links between the shocks since quite a while already and tried different set ups but i always have a lot of torque twist do you have this problems also?
strerath is offline   Reply With Quote
Old 05-24-2011, 07:14 AM   #38
BLADE's Avatar
I dont seem to notice any torque twist I will double check next time I am out running it.
Blade
Old 05-24-2011, 10:59 AM   #39
Love the bottom end. Not a huge fan of the roll cage. Thinking maybe with an aluminum roll cage, changing the phillips for button hex. Bottom end looks
bouncingbabyboy is offline   Reply With Quote
