05-16-2011, 11:43 AM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: Chelsea, MI
| Metal Trans gears
Anyone know if there are metal trans gears and where I can get them. I keep sheering the teeth off the small trans gear. Thanks |
05-16-2011, 11:49 AM | #2 |
Newbie Join Date: Jan 2009 Location: Brampton, Ontario
never seen them yet. what motor and battery are you running? |
05-16-2011, 11:53 AM | #3 |
I'm running a predator80 on a 2s Lipo with a 55t spur gear. I think I just found one http://cgi.ebay.com/Losi-Micro-Crawl...item2310cf308d |
05-16-2011, 12:17 PM | #4 |
nice find
05-16-2011, 06:04 PM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Ive seen those. said to be the same part # as its updated. before you order make sure its actually metal and not just the pic. are you sure there is no binding in your case? People have run outrunners and big 130 can 90 turn motors and not stripped gears. maybe try the hot racing case first. it makes the trans smooth as butter |
05-17-2011, 05:18 AM | #6 |
Newbie Join Date: Jul 2010 Location: south australia
Second the hr alloy trans can't believe the difference that made so silky
05-17-2011, 07:38 AM | #7 |
I am running the HR trans case. No binding, nice and smooth. My wheel however, are extremely heavy.
05-17-2011, 10:14 AM | #8 | |
Pebble Pounder Join Date: Jan 2011 Location: USA
05-17-2011, 05:21 PM | #9 |
Pebble Pounder Join Date: Apr 2011 Location: KC
Sure you didnt get dirt or grit in the tranny? the stock transmission is not really "airtight" there's a small opening next to the motor, stuff can get in and cause some issues. I usually remove the motor from the transmission and blow on it while turning the tranny to make sure there's nothing trapped in the gears.
05-17-2011, 07:12 PM | #10 |
Damn.. Yea I'm sure there's no grit or anything in the trans case. I only drive it inside. When I opened it up it was completely clean. |
05-18-2011, 11:16 AM | #11 |
05-18-2011, 04:42 PM | #12 | |
I'm pretty sure a lot of people run with their slipper basically locked. Gears were running super smooth.. idk.. | |
05-18-2011, 05:48 PM | #13 |
Exactly, that's why I was looking for metal gears. Someone needs to make them I'd be in for several sets.
05-18-2011, 06:06 PM | #14 | |
has anyone come across the center trans shaft gear in metal like the EBay pic? perhaps the trail tekkers? | |
05-18-2011, 06:21 PM | #15 |
Everyone send HR an email saying that they should make an aluminum gear set. Eggoz: What aluminum slippers are you running and where can I get them? |
05-19-2011, 02:12 PM | #16 |
Ive done the same. just a few washers and a 2nd top slipper and you are good it has JUST enough room to spin without rubbing. I doubt you could go any bigger than 59t without cutting the shaft for clearance.
