07-10-2011, 05:14 PM | #21 | |
Quarry Creeper Join Date: Jun 2004 Location: Utah
Blade | |
07-24-2011, 04:01 PM | #22 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
After reading some folks were having trouble w/the set-up on thier rigs w/the Ridgeback I wanted to find the time to see what problems anyone could run into. I will have some things to talk about for the build & will also be finishing up w/panels. I have good flex w/o any binding. I really like the Mickey Thompson tires for this chassis. Getbent's Famous Powerhouse 90t |
07-24-2011, 04:16 PM | #23 |
Quarry Creeper Join Date: May 2011 Location: USA
Is that almost a six inch wheel base?
07-24-2011, 04:18 PM | #24 |
5.5 on the head.
07-24-2011, 04:19 PM | #25 |
t buck Truck looks awesome Blade |
07-24-2011, 08:29 PM | #26 |
Rock Crawler Join Date: Dec 2005 Location: houston
Looks good T-buck, I finally got around to putting mine together too. No binding problems at all with mine, I didnt do anything special, just bolted it together with no issues at all. I think BLADE did great with this chassis! Cant wait to see what you come up with for the panels! |
07-24-2011, 09:26 PM | #27 |
Grr... I like hearing that things are good with some peeps builds, but I would really like the success story to be coupled with a how to, or a step by step, or something to give indication so those of us that utterly failed with this chassis can help us figure out what to do right. As it stands, those of us that have failed at this chassis are still in the dark, like getting it to work is a part of the Colonel's 7 secret herbs and spices or something and only a certain few are previe to the knowledge... lol. So I am really looking forward to a build design/review from here, and hopefully T-buck is able to take some time to do so. |
07-25-2011, 03:03 AM | #28 |
Quarry Creeper Join Date: Oct 2010 Location: Newport, South Wales
It is pretty straight forward to get this working right, stretch the wheel base out to 5.5" or more. If you try to run the stock links you will have nothing but issues with binding. There are several threads and posts in the micro mod bible thread on how to make your own links and to stretch the drive shaft's.
07-25-2011, 03:13 AM | #29 | |
OR This just isn't as good as the Blade TMC, which I'm using as comparison, and I have no desire to go down in performance, even a little. So maybe I have gotten it right a few times but the Blade TMC still out performs it... which could be to I guess. No one has done a comparison yet. | |
07-25-2011, 04:37 AM | #30 |
If you are getting a lot of side to side wobble then something isn't right with yours. I have maybe 2mm total of side to side wobble on mine and it is very stable. Here are my measurements for reference, for the link measurements they are center to center. Lower links (front and rear): 55mm Front upper links: 55mm Rear upper links: 50mm Tube for extending front drive shaft: 25mm long Tube for extending rear drive shaft: 28mm long Mounting spot for front link: middle hole on chassis Mounting spot for rear link: top hole on chassis Mounting spot for front and rear shocks: top hole closest to chassis It has a 5.375" WB with no binding, prefect amount of flex, and climbs like a champ. The difference for the upper link lengths is a matter preference, for servo clearance, and retain certain drive line angles. Last edited by dockman; 07-25-2011 at 04:40 AM. |
07-25-2011, 05:51 PM | #31 | |||
| Motor is awesome as usual... Thanks for the compliments. Quote:
The only comparison is a couple photo's | |||
07-25-2011, 05:56 PM | #32 | |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
T-buck, the rig looks great. Based on this build thread and dockmans info, I had the wife order a ridgeback for my micro for my birthday. | |
07-25-2011, 10:56 PM | #33 |
Newbie Join Date: Mar 2010 Location: Rancho Cucamonga
T Buck... Looks awesome! I really love mine! I did not stretch mine out as far and still find it to work good. I have been running it and me TMC together on my home track and they both work better than I expected... I do not see that you used the upper link part that Blade had created. Are you still working on that part or did it not work? I am very interested in your body panels. I have not started that yet. |
07-26-2011, 12:23 AM | #34 | |
07-26-2011, 09:16 PM | #35 |
Thanks for posting info Guys and the truck is looking awesome T-Buck, I will do my best to get some of my build info up a soon as I can I do apologize for the lack of build info just not enough time in the day to get everything done plus my Crawler addiction lol. Thanks Blade |
07-27-2011, 10:42 AM | #36 | |||
Little more to do yet. | |||
07-27-2011, 08:43 PM | #37 |
For those that use my measurements for reference the difference in the front upper link length is so at full compression of the suspension the servo does not hit the front of the chassis. This will only work with certain servos, myself I use a HS-65MG. You can of course extend the links a little more or change the mounting points for the shocks to gain clearance so that nothing interferes with the servo when the suspension does its thing. Just make sure all changes in link length are proportional so the suspension geometry remains intact. I will see about posting some close up pics of my rig so you can see how everything sits with my setup. |
08-30-2011, 11:07 PM | #38 |
Newbie Join Date: Dec 2010 Location: In my tow truck..
sweet build, pics???? |
