09-30-2011, 11:15 AM | #61 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
11-03-2011, 07:53 PM | #62 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
I just wanted to add a bit about widening the Sumo axles via wideners. I run BWD Vertex wheels, so only their wideners work. I used BWD spacers and modified CrawlerX wheelnuts. The axle stub threads are larger, so I had to drill out the wheelnut and rethread it again. No biggie, but it is an option. The CrawlerX spacers work too, but again, the wheelnuts need modified just the same.
03-02-2012, 12:06 PM | #63 |
Newbie Join Date: Jan 2011 Location: SLC
| Re: Redcat Sumo micro crawler (RSMC) parts breakdown and losi compatibility
I don't have a lipo charger. but it do have a super brain charger I use for my AX10 can you please point me to what battery I should buy for my Redcat Sumo Crawler and where? |
03-02-2012, 12:42 PM | #64 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: Redcat Sumo micro crawler (RSMC) parts breakdown and losi compatibility |
03-02-2012, 04:03 PM | #65 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Redcat Sumo micro crawler (RSMC) parts breakdown and losi compatibility Check my posts on page 10 of the battery thread sticky thread at the top of this micro forum . there are links to 2 value hobby lipos and the US warehouse hobbking lipos ( when in stock) Valuehobby is always in stock and the cheapest best bang for buck.
03-02-2012, 04:15 PM | #66 |
03-03-2012, 12:59 AM | #67 | |
| Re: Redcat Sumo micro crawler (RSMC) parts breakdown and losi compatibility Quote:
I don't have a lipo charger ;) lol | |
05-02-2012, 11:32 PM | #68 |
Pebble Pounder Join Date: Feb 2010 Location: yankees suck
great thread, answered many questions i had, nice to see axles w wideners all lined up... but the first bunch of pics wont load for me |
05-03-2012, 05:15 AM | #69 |
07-15-2012, 02:28 PM | #70 |
Just some "official" specs I found. Haven't confirmed them but I thought Id share. Motor gear ratio: 1: 65 Front/rear gear ratio: 1: 1.85 The whole gear ratio: 1:2.7 |
07-28-2012, 04:55 AM | #71 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
Out of curiosity, if I was to purchase one of the Pololu micro gearmotors, which ratio would be the best upgrade as far as more torque without losing too much speed?
08-07-2012, 09:28 PM | #72 |
Newbie Join Date: Oct 2011 Location: Saskatoon
I was wondering if the losi wheel extensions would be enough to run the miclaw tires on the sumo crawler or do you need wider wheel extensions than that?
09-15-2012, 09:41 AM | #73 |
Pebble Pounder Join Date: Feb 2008 Location: Myrtle Beach
| Re: Redcat Sumo micro crawler (RSMC) parts breakdown and losi compatibility Can you tell me what the second tire form the left is? IT looks like it is sandwiched between a Miclaw, and an RCWD Bogger. I looked back through the posts with broken pics but couldn't figure out if there was a heading for this one. I really appreciate all of your effort. I was looking for a good comparison of the RSMC to the LOSI, and you definitely provided that. |
09-15-2012, 10:01 AM | #74 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
Those are the So-Real boggers for diecast models. Paul from ebay sells some soft urethane ones. URETHANE TSL Boggers 4ea fit Custom MINI-Z & XMODS | eBay |
09-17-2012, 12:47 PM | #75 |
Thanks MG! I just ran across him on eBay, and was coming back here to confirm that;s where they came from. I think I'm in need of some, as the RC4WD boggers, are just too tall for my scale rig. Sorry to stray OT..... |
12-06-2012, 01:40 AM | #76 |
Out of curiosity, what size is the motor on one of these? If I get a Pololu gearbox can I get a higher torque motor for it?
12-18-2012, 01:14 PM | #77 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
hope this thread benefits me some day... glad it is kept pretty up to date!
02-28-2013, 01:40 AM | #78 |
Newbie Join Date: Jan 2013 Location: Summerland
im getting 2 tommarrow, im honestly buying for the pcb board, for my trekkers, what to do with the rest of the sumos, idk, if the axles are as good as every body says, could i mount them on a trekker?
03-13-2013, 02:27 PM | #79 |
Rock Stacker Join Date: Mar 2013 Location: Orlando
I've tried different motors including a longer one from ebay, it worked real good but the best beneffits have come from the latest motor Ive used, its from a tower pro mg946r servo, you will need 4x 2mm washers to mount it onto you existing gearbox, and you will need to transplant the pinion from yout motor to it, but once you do the sumo will turn into a beast! It will be faster and MUCH torquier! The best beneffit will be the lower running temperatures you will get on it since it hardly has to work at all because of its huge improvement in torque. My buddy has been doing the losi into sumo transplant which would also work if thats the way you want to go but I think the "big block" choice might be a bit easier and safer, but again, theres choices for you |
03-14-2013, 02:42 AM | #80 |
Newbie Join Date: Jun 2011 Location: france
Thanks gamyrc, that's a very good information.
