08-05-2011, 11:23 AM | #1 |
Newbie Join Date: Aug 2011 Location: somewhere in az
| losi micro crawler into trekker?
how hard is it to convert a losi micro crawler into a trekker? minus electronics? basicly i found the rtr micro crawlers for 79.99 and the trekkers are 149.99 so im wondering what to do and if it would save money buying a crawler and converting it. also i would be converting it to brushless and a digi radio
08-05-2011, 11:30 AM | #2 |
RCC Addict Join Date: Nov 2007 Location: -
I think all you would need is the Trekker frame and links and driveshafts. Because the trekker has been made longer than the MRC. But everything else is the same...axles,motor,reciever,servo, etc... You can get that frame from eBay.com Here is the frame http://cgi.ebay.com/Losi-Aluminum-Ch...item5199b61900 Drive shafts... http://cgi.ebay.com/Losi-Molded-Cent...item3368b4ff3d I did not see links though. Last edited by Hydro-Tank; 08-05-2011 at 11:36 AM. |
08-05-2011, 11:33 AM | #3 |
cool i think i might pick up 2 micro crawlers to convert since there only 79.99 and craigslist the electronics
08-05-2011, 12:13 PM | #4 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
Don't forget the 4 extended upper shock mount ball studs. The shocks will bind hardcore against the Trekker frame unless a shock crossmember is made.
08-05-2011, 10:13 PM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
and the wider hexes and stub shafts. the extra width is nice
