09-30-2011, 08:18 PM | #41 | |
Newbie Join Date: Sep 2011 Location: US
10-02-2011, 03:54 PM | #42 |
Nevermind I figured it out- I just sanded down the axel nut and cut the round backing flange off- works great so far!
10-03-2011, 04:41 PM | #43 |
Rock Stacker Join Date: Aug 2011 Location: the middle of nowhere
Sorry about that, I've been working crazy hours lately..I ended up throwing those barrel nuts away, after swapping in the sumo hexes. Now I can use the normal ones I had in it before. They were pretty easy to make. I just cut 1/8" off some losi ball link cups, used a dremel to shave one end down to fit in the wheel bore, screwed a hex head screw in the large end, then threaded the small end onto the axle shaft. Worked pretty well. Tried mounting the suspension inboard on the sumo, but it kept binding, so I decided to try the HR shocks. I have heard nightmare stories about them and figured I would be spending hours getting them to work right. Not the case here. Super smooth right out the packaging. Must have got lucky. Ended up using some servo screws that I had laying around for mounting to the axles. They look good, and work great. Also gained some clearance for the shell. Still have a few more things I would like to do, so just waiting for some more parts to show up. Sent from my EVO4G using Tapatalk Last edited by longhammer; 10-03-2011 at 08:56 PM. |
10-10-2011, 09:15 PM | #44 |
So, I got the rest of my parts in the mail, so I managed to get most of the sumo completed. I extended the wheelbase by about a half inch using custom links, built the rest of the steering linkage, installed two TPro mg90 servos. Also picked up another trekker shell. Still lots more left to do, but coming along quite nicely. Debating on whether or not to cut the bed rails off and building a tube rear.. Sent from my EVO4G using Tapatalk |
10-10-2011, 09:28 PM | #45 |
Quarry Creeper Join Date: Oct 2010 Location: NOR-CAL
Looking good.
10-10-2011, 09:55 PM | #46 |
RCC Addict Join Date: Nov 2007 Location: -
Aw nice dude. Looks sweeeet!
10-17-2011, 03:47 PM | #47 |
Been pretty busy at work, so my micro time is pretty scarce, but I did manage to somewhat finish the sumo...ended up basically making a twin to the trekker. Cut the bed sides off and fabbed another tube rear. I ended up working Sunday, so I brought both trucks to work to try out the rock garden...found some pretty cool channels where the rain had washed some of the ground away. Did a little vid shooting. Just need to put it together and post it. Sent from my EVO4G using Tapatalk |
10-17-2011, 05:23 PM | #48 |
Your micros look great.
10-17-2011, 06:21 PM | #49 |
Thanks! I do need to pick up trekker hexes for the trekker. Track is way to narrow with the sumo ones. I ended up having to fab temporary lower links to use until I get the spare sumo driveshafts for lengthening. All in all, I'm pretty happy with both trucks..not to sure I can improve them any further than they are now except for better motors
10-17-2011, 06:49 PM | #50 | |
Yeah they look great.The tube beds look real nice.I'm moving this weekend coming up so after that i'll be able to work on mine again.Motor upgrades would be nice. Quote:
01-29-2013, 01:42 PM | #51 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| Re: my first rig..trail trekker
Your trucks are amazing!!! |
03-08-2013, 11:55 PM | #52 |
Newbie Join Date: Jan 2013 Location: Summerland
what is ur steering linkage??
03-09-2013, 09:21 AM | #53 |
Rock Stacker Join Date: Jul 2012 Location: MS
The trekker has hot racing aluminum steering links and the sumo has custom made (made from ball links, allthread, and aluminum tube) linkage
