Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Servo issues! HELP!
Old 09-17-2011, 08:44 PM   #1
Default Servo issues! HELP!
Sorry I'm asking for help again, but can someone please help me with my servo? It's Spazzing out and can't be controlled by my transmitter... It's the servo/transmitter that came with my car, so It's stock. Is the servo busted or can I fix it somehow?!?! HELP!
Thanks, Kyle
SpeedyCrawler is offline   Reply With Quote
Old 09-17-2011, 09:12 PM   #2
This should help!! http://www.rccrawler.com/forum/showt...67#post3250667
MICHIGAN CRAWLER is offline   Reply With Quote
Old 09-18-2011, 12:19 PM   #3
THANK YOU!!! My servo is being stupid so I think I'll order the more expensive one. Thank you a whole bunch though, I'll make sure to post news on my build!
Old 09-18-2011, 02:48 PM   #4
No problem!! My servo does that every other run, and it looks like it's having a seizure lol!! I will probably have to upgrade one day too!!
Old 09-18-2011, 04:39 PM   #5
Great idea! lol hope you upgrade soon!
Old 09-19-2011, 05:39 AM   #6
I just went through this myself. I tore apart the stock servo and inspected it first. I couldn't see anything wrong, but it was a PITA to put back together with the tiny gear stack. It seemed to work fine again for about 2 packs and then started spazzing again.
I replaced it with the Hi-Tec HS-65MG. For a stock steering linkage cut down the single arm horn to use the shortest hole. You'll also need to open the hole up a bit with a small drill bit so the ball stud can thread in.
mstyer is offline   Reply With Quote
Old 09-21-2011, 09:52 PM   #7
Okay, I ordered the same servo and it came today. I was pretty pissed when I saw that It doesn't fit into the stock receiver. Does yours fit? or will I need to upgrade that too?
