11-01-2012, 06:32 AM | #1 |
Newbie Join Date: Jun 2007 Location: Over There
| Anyone cut there trekker chassis down?
Was thinking about cutting the chassis just in front of the shock mounts. Is there gonna be any disadvantages to this other than not being able to mount the body on? |
11-01-2012, 05:35 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
| Re: Anyone cut there trekker chassis down?
If you want a shorter chassis, just pick up an McRC chassis. You will lose some rigidity in the front as well because the front brace will disappear. The McRC chassis is steel so it won't flex.
11-01-2012, 06:46 PM | #3 |
Good point. I wasn't wanting to shorten the chassis just wanted to relocate the battery to the front. With the stock chassis there isn't enough clearance to mount it on the servo.
11-01-2012, 09:13 PM | #4 |
A smaller battery would help. Good time to upgrade to a Li-Po!
11-02-2012, 06:07 AM | #5 |
I'll try the Li-Po first before changing the chassis. Thank ya sir.
11-02-2012, 04:53 PM | #6 |
Pebble Pounder Join Date: Sep 2012 Location: Pollock Pines
I have never cut my frame, however, I did drill a bunch of holes in it. It seemed to help some. I only drilled the highest rail and left the lowers alone.
11-02-2012, 05:05 PM | #7 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
and here I just got rid of my losi Micro rockcrawler chassis plates in leu of a custom chassis.
11-02-2012, 05:15 PM | #8 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
i have crawler chassis plates if you are interested in them
10-11-2013, 10:53 PM | #9 |
Newbie Join Date: Sep 2013 Location: Ontario
I found the delrin chassis from the toyz pretty good on my micro crawler. Got a trail trekker coming in almost bought one for it, until I thought it wont be enough this time.hehehe |
10-13-2013, 06:19 PM | #10 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
Just tried a Lipo on my McRC w/90t from Danally and am very impressed! Crawling performance is now worlds above the factory NiMh set up. Also widened the rims, changed the springs, moved the electronics/battery and added some lead on the axles. Ordered a set of chassis plates for my Trekker because I'm gonna cut the top rails back and don't think the slight loss of rigidity will be noticable on such a lightweight set up. Can always add a small crossmember if needed. Maybe can just bend the top rails in and tie them together with a bolt/nut or two. Working on some larger tires, for the small factory rims, to gain some ground clearance/approach angle since I seem to have gotten in on the Micro Crawler scene too late to get Miclows. Don't really want to have the monster size mini wheels on my Micro. Last edited by anuthabubba; 10-13-2013 at 06:25 PM. |
10-13-2013, 08:48 PM | #11 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
yes lipo and 90t make a world of difference.... then you did all the others.. well played.... larger tires? like? I have boggers/claws/MiClaws and all are great for their purpose.... |
10-13-2013, 08:58 PM | #12 |
Have some Super Swampers ordered. Clipped every other lug on the OEM ATs and got good results over the Losi Claws. Would like to have some of the sticky Losi Claws that were taller. Haven't found any Miclaws yet.
10-13-2013, 08:59 PM | #13 |
| Re: Anyone cut there trekker chassis down? |
Anyone cut there trekker chassis down? - Similar Threads | ||||
anyone raise the lower links and cut the chassis | Jcplante | Redcat Crawlers | 8 | 08-26-2011 02:00 PM |
Question for Trekker (or Trekker suspension link) owners | Markhpnc | Losi Micro-Rock Crawler | 9 | 08-12-2011 05:43 PM |
Trekker with DP Torsion Chassis | Evilinside | Losi Micro-Rock Crawler | 1 | 05-16-2011 07:13 PM |
Which tools to cut stainless chassis? | racecarking123 | Tools, and Procedures | 13 | 07-03-2005 04:23 AM |
