03-28-2012, 09:30 PM | #1 |
Pebble Pounder Join Date: Jan 2012 Location: ohio
| fraze's micro build DDT Big Block'd TMC
Decided to make a thread for the build. i'll list what i have done so far -hr shocks (light springs in the front med in the back) -aluminium tranny case -aluminium skid plate -90t ddt predator motor -crawlerx wideners thats it so far things to come are -tmc v2 bodieless chassis(ordered waiting to be shipped) -vertex beadlocks if they ever come back in stock -rock lox tires i think cant decide which ones i want -custom links at some point here is link to the pictures on my other thread if care to look which would you mod first Last edited by fraze; 04-25-2012 at 09:55 AM. |
03-29-2012, 11:34 AM | #2 |
| Re: fraze's micro build
Will have to say the new motor is nice snuck home for 10 min from work to test it out,couldn't wait all day haha, plopped it down in could holes normally would get stuck in and it powered right out. Still a few things I can't make it over but that's tires arnt gripping and links getting in the way, that will down the road. Still waiting for chassis to be shipped anyone elses order take almost a week to ship from crawlerx? Edit : got the shipped email so update pictures soon Last edited by fraze; 03-29-2012 at 02:03 PM. |
03-29-2012, 08:20 PM | #3 | |
RCC Addict Join Date: Jun 2007 Location: MESA
| Re: fraze's micro build Quote:
03-29-2012, 09:42 PM | #4 |
so am i quite glad i had you rewind it not i have an extra stock motor what to do with it haha
03-31-2012, 09:58 AM | #5 |
got the chassis in today so started deburring and piecing it together almost put together having issue threading one of the braces so worked on that till i had to head out try to finish it after i get done with my errands |
03-31-2012, 02:41 PM | #6 |
few more actualy stuck the motor in backwards compared to how it was suppose to go in....oops fixed it tho and its a roller having issues with the shocks feeling rough so goin to take them off and do the hr shock mod thing i read about. must be something with the angle there at,on the TT there felt fine not sure it for today unless i get some more free time |
03-31-2012, 03:00 PM | #7 |
easy fix just moved the shock mounts forward freed up the shocks nicely few poser shots Bod-ah approves lol |
03-31-2012, 08:19 PM | #8 |
| Re: fraze's micro build and she runs need to find better way to do the wires and esc just wanted to see it run some also not sure how well the links are goin to work out so goin to have to make my own sooner then planned |
04-01-2012, 09:25 AM | #9 |
took it out today ^ favorite picture so far really happy with it so far i need to do something with the tires stock ones just arent cutting it they form to nothing and just bump up and down off the rocks Last edited by fraze; 04-02-2012 at 03:24 PM. Reason: added a picture |
04-01-2012, 10:05 AM | #10 |
as i was waiting for the battery to charge i decide to find a better way to stick the esc in so i had an idea to flip the rear shock mount upside down and slide it in there but while doing that i found somewhere i like better haha but kept the mount the same it raised the back by 1/4 inch. i like the way it looks now but may be to high. picture to show what i mean and one of the ride height now,also i traded out the back springs for the softest of the three travels alot easier now |
04-01-2012, 08:23 PM | #11 |
rought cut of my side panel template |
04-02-2012, 01:11 PM | #12 |
not sure if i like it or not...what you think. what do you guys use to make it stick to the chassis glue? or what else? |
04-03-2012, 08:55 PM | #13 |
decided to go a different direction with panel goin to make a full side cover with a protective piece of thin plastic i got the plastic cut to size n shape now just waiting till i come up with an idea to make the design on the side have the pieces of plastic just need to figure out how/and find the design i want hard to see but its there lol |
04-03-2012, 09:16 PM | #14 |
RCC Addict Join Date: Nov 2007 Location: -
Looking good man. How are you going to mount that clear piece? I thought that the Mountain Dew panel looked ok. |
04-03-2012, 09:53 PM | #15 |
Rock Crawler Join Date: Oct 2011 Location: minot
LOVED my tmc. i never jacked up the rear like yours tho, i bet its got good break over abilities!
04-03-2012, 10:05 PM | #16 | |
also i change the back shock mount back to normal was a little "floppy" and it helped some but cog is little high still with the battery on it | |
04-05-2012, 05:26 PM | #17 | |
order some all thread to make my links should be in by the end of next week was hoping for sooner but o well, will have to ponder on the side panels alittle more to fill in the time void from now till then i need to order another micro just to keep me busy haha want to make a foff just been putting it off i have an 80t ddt motor with aluminium tranny case sittin on my trekker chassis may go ahead and order a sumo to finish it up now to figure out what to tell my gf to why i need to spend more money so soon Last edited by fraze; 04-05-2012 at 06:10 PM. | |
04-05-2012, 06:08 PM | #18 |
this is how it will be held on prob leave it at that seems to be on there good and i like it so far now just to get the actual design that i want to go behind it thinking about cutting off the little tabs at the ends... on the back side the drill got away from me and ripped it threw should of just used my fingers like what i considered at first but o well live and learn |
04-06-2012, 09:36 PM | #19 |
and what i've come up with for the hood section with the front zip tied just need to do the back some how made a back on but can't figure out how i'll get it to stay on so may leave it out haha |
04-07-2012, 02:10 PM | #20 |
Been looking at the rear lock outs what exactly does that do and whats the advantage of them?
fraze's micro build DDT Big Block'd TMC - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
My micro course build - something different I think | Mud Puppy | Micro Scale Rigs | 1 | 01-02-2012 08:37 PM |
how do you build a micro dig? | lordjasper1988 | Losi Micro-Rock Crawler | 2 | 06-21-2011 04:09 PM |
Micro FJ Build | Grumpster1980 | Micro Scale Rigs | 11 | 05-04-2011 09:15 PM |
Micro Rubicon Build | Pointman | Micro Scale Rigs | 24 | 11-09-2010 06:58 PM |
