08-01-2012, 10:28 AM | #1 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
| BWD Micro Barrel Nuts/Widener Kits - Update
I know this has been an issue for a very long time...and I finally have an update. I have a small batch of samples arriving here this Saturday of my micro barrel nuts turned from brass. If they check out, I have an order for a few hundred of them being produced from brass that would be able to be here within a couple of weeks. Interest still??? Don |
08-01-2012, 10:47 AM | #2 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: BWD Micro Barrel Nuts/Widener Kits - Update
Yes Don! Count me in for 2 sets! (8 pcs). I really hope they fare better than the aluminum ones.
08-01-2012, 10:50 AM | #3 |
| Re: BWD Micro Barrel Nuts/Widener Kits - Update They should be a massive improvement over the old ones...and now as long as they pass spec should finally be available constantly! The shop running them just happens to be a shop set up for SMALL precision turned parts |
08-01-2012, 11:19 AM | #4 |
I'm in need of some. |
08-01-2012, 11:49 AM | #5 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
Count me in for a few sets |
08-01-2012, 01:49 PM | #6 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
Hey me too don!
08-01-2012, 02:14 PM | #7 |
Rock Stacker Join Date: Mar 2010 Location: Oak Harbor
Count me as interested.
08-01-2012, 02:28 PM | #8 |
| Re: BWD Micro Barrel Nuts/Widener Kits - Update Awesome! I can hang with brass. A bit of weight and not as sift as the aluminum bits. Thanks for keeping us updated! |
08-01-2012, 02:59 PM | #9 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
Are they going to be painted or coated at all? I run in mud and water and really don't want to get my nuts stuck (pun intended). I'd personally prefer aluminum, but if all you can get is brass, I'll take what I can get! Been running without rear-steer for far too long!
08-01-2012, 04:25 PM | #10 |
Newbie Join Date: Dec 2011 Location: france
Interested as well Count me in for a set. |
08-01-2012, 06:08 PM | #11 | |
| Re: BWD Micro Barrel Nuts/Widener Kits - Update Quote:
even if he dosent you could coat them your self right? i honestly have no idea if u can just a suggestion! | |
08-01-2012, 06:47 PM | #12 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
Thanks for the update! I'm in for a few sets also |
08-01-2012, 07:00 PM | #13 | |
At the end of the day, I REALLY don't want my nuts to be frozen to the stubs when I forget to clean out the water after a creek run. Worse than losing one on the trail. | |
08-02-2012, 08:51 AM | #14 | |
08-02-2012, 11:13 AM | #15 |
Here's a pic of the samples...which should now be in my hands tomorrow. As for brass being a problem...the alum nuts strip too easily, stainless costs too much (at 14 bucks per nut my cost), delrin I don't think will hold up well either (and would cost a great deal more than the brass nuts)...which really leaves brass as the only cost effective option. If you're gonna be running through water, I'd put a drop of antiseize on when installing them.
08-02-2012, 11:46 AM | #16 |
Sweet, when and how much!?
08-02-2012, 04:48 PM | #17 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
you know in down for a set or two.... i can finally finish my micro quad build .... thanks for the update don... now i just need axial to make more hardened steel gears for my other project i have going... |
08-02-2012, 05:19 PM | #18 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I'll be grabbing a set
08-04-2012, 08:02 AM | #19 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
Would these be available to fit the RedCat Sumo?
08-05-2012, 07:00 AM | #20 |
Newbie Join Date: Jul 2012 Location: Jax. FL----Afghan atm
Count me in I just stripped the last of my aluminum crap ones and the micro is out of commission for now because for some reason i dont have the stock wheel nuts.
BWD Micro Barrel Nuts/Widener Kits - Update - Similar Threads | ||||
BWD Bullet Proof Micro Widener Kits! | billet works | Losi Micro-Rock Crawler | 97 | 05-12-2012 05:50 AM |
Ok to use threadlock on the BWD widener barrel nuts? | StickyWheels | Losi Micro-Rock Crawler | 4 | 01-02-2012 12:47 AM |
Barrel Nuts? | ReaperGN | General Crawlers | 12 | 05-22-2011 09:56 PM |
