03-06-2013, 10:55 PM | #101 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Rims with an offset...
Some reading back is in order.
04-17-2013, 07:39 PM | #102 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
Finally tried the UHD mode for rims. Wow!!! All rims will be printed in UHD mode. I'm embarrassed of the previous images. :( Last edited by Fungi; 04-17-2013 at 08:14 PM. Reason: added two more images. |
04-17-2013, 07:54 PM | #103 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
this might be getting a bit too detailed for such a small rim/tire. but is it at all possible to do a hub and then have the rim attach to that, rather than having a pin/hex mounted wheel?? or am i trying too hard.. lol and my other Q, is it possible to have a less offset rim too? to narrow the track width rather than widening it ? |
04-17-2013, 07:56 PM | #104 |
UHD , is that Ultra High Definition? the rim you posted looks clean as!! just awesome. |
04-17-2013, 08:04 PM | #105 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Holy shit! That's awesome man. I might just have to buy a set to match my 1:1 wheels. Of course I'll have to paint the outer ruins though. Still need to fix that 7th lug though.
04-17-2013, 08:35 PM | #106 |
I'm not 100% sure I know what you are envisioning. Can you sketch something out? ;) The reduced offset is definitely possible. Yes UHD is Ultra HD. I use HD for the chassis because they are so tall. The geometry of the rims, short with a face that requires highest clarity, lends itself to UHD. There is one above UHD but It's crazy accurate and crazy slow making parts. Ok, ok so the lugs can be removed. hehe Due to design limitations the lugs don't clear the wheel nut when reduced to 5 r 6. I do want to make a thin laser cut part for the outer ring. It's coming together. |
04-17-2013, 08:40 PM | #107 |
coming along well
04-17-2013, 09:15 PM | #108 |
upon thinking about it, and going back to check out the body and how the stock losi rims fit, i think ill stick with the losi offset. maybe maximum +2mm on either side. also, the hub idea, way too finiky.. even if done well, the nuts n bolts to hold it all together would not take much to strip out i reckon... i was thinking about something along the lines of the RC4wd micro pressed steel beadlock. something like this >> |
04-18-2013, 11:15 AM | #109 |
Rock Stacker Join Date: Jul 2012 Location: MS
Do you have a rough time frame of when you will be ready to start selling?
05-26-2013, 10:24 AM | #110 |
Finally got the chance to update photobucket with the jeep rim images. :( I painted them with my airbrush. |
05-26-2013, 10:47 AM | #111 |
They look great
05-26-2013, 10:48 AM | #112 |
Tidy like an ocd's underwear drawer!
05-26-2013, 05:00 PM | #113 |
they look so much better with a lick of paint on |
05-26-2013, 05:06 PM | #114 |
Pebble Pounder Join Date: Nov 2012 Location: CO
Those Jeep wheels are spot on same as my old jeep wheels
05-26-2013, 06:01 PM | #115 |
Thanks for the feedback... It's just one coat of Tamiya silver with an airbrush. My first time... I should have used some alcohol to thin the paint. I used water but it appears to be ok. Oh! Hope to be selling this fall. Klampy, why you gotta live in frickin' Australia man? lol >.< |
08-31-2013, 07:35 PM | #116 | |
Pebble Pounder Join Date: Nov 2010 Location: Cleveland, Ohio
| Re: Rims with an offset... Quote:
sooo.... any interest in selling me just the file for this rim? I have access to a 3d printer at work. | |
08-31-2013, 08:00 PM | #117 |
| Re: Rims with an offset... |
08-31-2013, 08:18 PM | #118 |
Shipping though... :(
08-31-2013, 08:28 PM | #119 |
eh, surely it wouldnt be more than a small padded envelope? theyre sorta cheap, i know they are from my side. when i sent the AX10 chassis plates to the US in an envelope it only cost me $5-$10. wasnt terrible.
08-31-2013, 08:32 PM | #120 |
are 1.9inch versions of my requested Jeep rim out of the question? so 12mm hex, fairly neutral offset, 1.9 bead. etc. ??
Rims with an offset... - Similar Threads | ||||
Axial offset rims... | h8z2luze | Team Losi Comp Crawler | 7 | 08-11-2009 09:22 PM |
Most offset rims? | James Luce | Tires and Wheels | 6 | 12-12-2005 05:42 PM |
