01-11-2013, 01:03 PM | #41 |
Pebble Pounder Join Date: Nov 2011 Location: Oahu
| Re: The ROCK!
nice rock! get some expanding foam to fill out where ever, i think thats just what you need to get that thing really sweet |
01-12-2013, 10:49 PM | #42 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: The ROCK!
that couldnt be a more perfect terrain base. and soooooo much lighter than the pile of rocks and bricks i keep re-arranging on the living room floor.
01-13-2013, 06:44 AM | #43 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: The ROCK! |
01-16-2013, 10:11 AM | #44 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: The ROCK! |
02-21-2013, 10:59 AM | #45 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: The ROCK!
Here's some more images of the ROCK! I finished the trim. There is a 1/8" groove for holding a clear acrylic panel about 4" high, to catch roll overs from hitting the floor. I used cabinets under the 4' x 4' top for storage. I need to glue some sand in areas to increase traction. I've never made it to the top since it's been painted. :P |
02-21-2013, 11:44 AM | #46 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: The ROCK!
Really? You've never made it to the top? I've made it several times with my Trekker and maybe once with my McRC, but I used the Rustoleum stone paint, which adds lots of grip. I'll have to snap a couple pics of it when I get a minute. The stuff I used for shrubbery, though, didn't stick very well with 3M spray adhesive. Need to rethink that a little bit. Not to mention it looks like bud. Yours looks great, though! Thanks for the idea. |
02-21-2013, 06:22 PM | #47 |
| Re: The ROCK!
I used to climb it before I painted it. I suspect the polyurethane coating slipperied it all up. It needs something... Yeah I have some bud to put on it too. haha You are very welcome! |
04-12-2013, 07:38 AM | #48 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
| Re: The ROCK!
This is freaking awesome! I just snagged one at HD.
04-16-2013, 07:30 PM | #49 |
Quarry Creeper Join Date: Feb 2013 Location: Detroit
I copied, first pic is color second is stone texture. I want to get some ToughGrab or whatever its called & glue small rocks maybe styro foam rocks to all the areas that are impossible. Make some cool lines. Might have to screw it to some 1/8" & make it lil bigger. Anyways I'm just throwing it in my backyard micro course to add to it. |
04-17-2013, 05:21 AM | #50 |
| Re: The ROCK! I'm building up around those areas, specifically the backside, with small limestone chips in order to make more lines that can be run.
04-17-2013, 11:46 AM | #51 |
I plan on leaving the back side & getting another then build a bridge out of florist wire & sticks. To copy this mess...which i will be destroying. Its sweet but a mess & too big to get outside lol Only spot i couldnt conquer is the really steep rainbow looking climb thats on the lower level. To the rear left. |
04-23-2013, 11:05 AM | #52 |
Newbie Join Date: Jul 2011 Location: Cloverdale
| Re: The ROCK!
What a cool idea, plus it is mobile which makes it even better, might just have to invest into one of these lol
04-30-2013, 07:49 PM | #53 |
Newbie Join Date: Nov 2011 Location: Central
| Re: The ROCK! |
05-05-2013, 07:19 PM | #54 |
| Re: The ROCK!
Had some time to work on my rock. Very impressed with the results! I wanted to glue sand to the rim edges, where the speckled paint wore off. I got some pet store sand and filtered the fine powder out by slowly pouring it out in a good breeze, or with a fan. I used polyurethane applied generously with a throw away brush, and used an old salt shaker to spread it out. It worked so well I'm going to do it again in some other areas. I had basically two runs and now have six! |
05-05-2013, 07:27 PM | #55 |
| Re: The ROCK!
Anybody found these pond liners with different layouts or features? I would like to use 2 or 3 of these on the indoor course I'm building, but I don't want a bunch of the same ones. Has anybody considered using a vacuum former to build their own? Would the size of something like this prohibit a guy from BUILDING a vacuum former on his own to replicate them?
05-05-2013, 07:53 PM | #56 |
| I just used the rustoleum stone to start after a good scrub w simple green & scotch brite & then a acohol cleaning. Then some play sand pictured w primer that looks like out west. Did that a couple times. Then bombed a whole can of clear on it. Sealed the sand really good. Until i ran it over w my truck, oops didnt see it. But that answers one of your ?'s about how to make it dif shape cuz actually turned out pretty sweet w some new lines. I forgot to buy this toy rail road bridge & some trees today at a flea market today so i could put both rocks together. Only $5 i'm bummin |
05-05-2013, 08:25 PM | #57 |
| Re: The ROCK!
I REALLY REALLY like that red rock look! Thanks for the input too. I've got a few bridges that I've built already put together, and a BUNCH of little plastic signs and stuff stock-piled for the course. I was hoping that I could find at least two different mountains to put the bridge between. I've got a 3'X6' table to build on and plan to do as Fungi has, and pack in some real rock around them. I started out building grout covered rocks, but they fell apart over time. I brought home a load of flag stone, it was too heavy in the quantity I needed for the layout I wanted. I checked on using Portland cement and fine sand over burlap, but it's expensive. In total, I've spent more time and money on failures than I should have for the time I've got to use my course. I'm really hoping something like this is the end-all. I'm on the edge of just giving up till Winter comes around again.
05-05-2013, 08:51 PM | #58 |
| Re: The ROCK!
Lowes has this, it's larger but much more expensive though... |
05-05-2013, 10:00 PM | #59 |
| Re: The ROCK! |
05-06-2013, 06:20 AM | #60 |
Try lava rock, super light, enough traction to cut stuff. Plus you can get that cool red color.
The ROCK! - Similar Threads | ||||
Blue Compound Mini Rock Claws & Rock Bashers are shipping | Rich Trujillo | Losi Mini-Rock Crawler | 29 | 11-22-2008 04:15 PM |
Verdict on best Comp tires? Rock stompers, Losi, Rock Crusher | toy4crawlin | Tires and Wheels | 58 | 02-21-2008 11:26 AM |
