09-15-2012, 10:05 AM | #1 |
Newbie Join Date: Jul 2012 Location: Lakeland
| Any one used micro t tranny/motor plate for a micro moa build?
I'm dying to have proportional dig on my micro crawler, anyone try to straight axle a micro t tranny? Any one use the qlo moa? Can the motors be replaced with losi size motors? Axial needs to make a micro moa!!!
09-15-2012, 06:23 PM | #2 |
| Re: Any one used micro t tranny/motor plate for a micro moa build?
Sounds interesting, what electronics are you going to run? I wonder if I could use 2 stock losi micro speed controls some how. What about b.e.c.'s? I get a bit of right rear axle turn (4 wheel steering) when I full throttle backwards, I've heard it's from voltage drop or something. Wouldn't 2 motors and 2 servos draw alot of amperage? I need to look into some qlo axles also!
09-15-2012, 07:05 PM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Proportional dig should be as easy as a QLO MOA,dual ESCs, & a Hacked GT3B radio. the hacked radio handles all the mixing. same setup I use on my Berg and many others with MOA's
09-15-2012, 09:14 PM | #4 |
I already have the gt3b and I've hacked it for four wheel steering, I have a hell of a time programming this thing, I wish there was a better manual. I've seen it being used for dig online. Can I do that with a three channel rx? I wonder if the qlo axles can be made to run predator motors. Thanks for any info fellas.
09-16-2012, 11:11 AM | #5 |
Im not sure what motors the MOA Qlos use but I have seen pictures of them next to a few others, I'm sure with some fabbing a predator could work. try searching the MOA QLO threads and Im sure you will see a few pictures. as far as the GT3B it can be a bit confusing at first, But once you learn the menus and names its easier. the GT3B hack thread in the Electronics sub forum has a few guides for the old & new firmware. Both of my GT3Bs still use the old firmware so i cant help with the new. and yes. you can run a MOA setup with a 3ch RX. thats what I use in my Berg. 1&3 are steering CH2 is throttle |
09-16-2012, 06:10 PM | #6 |
Thanks Spoo! I'll do some research and see what I can come up with. Starting to think it might be better to just get a 2.2 and start going to comps. I was going to start racing shortcourse again but I might just build a 1/10 comp crawler instead.
Any one used micro t tranny/motor plate for a micro moa build? - Similar Threads | ||||
Mini/Micro - MOA - Scratch Build | sweli | General Crawlers | 73 | 01-13-2014 04:46 PM |
*****Give Away *** Diamond Plate Micro Skin*** | Krawler Konceptz | Losi Micro-Rock Crawler | 31 | 03-07-2012 03:57 AM |
Mamba Micro Pro or Torque master XL ? for MOA , Berg | toy4crawlin | Electronics | 22 | 05-24-2011 07:53 AM |
micro t tranny swap | jwo | Losi Micro-Rock Crawler | 17 | 01-23-2010 09:27 PM |
