11-04-2012, 11:55 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| micro scale body?
Just got a quick question for you micro guys I want to build a garden crawler for the wife so if I wanted a body like this for a trail trekker what should I pay for it in brand new condition? and what do I need to mount it? Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-04-2012, 12:25 PM | #2 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: micro scale body?
Pictured is a 10 dollar truck from a local walmart, toysRus, target ect. if you wanted something a bit more detailed, for twice the amount you can get a model truck body, which looks a whole lot better. |
11-04-2012, 12:30 PM | #3 |
Would the die cast body cause the crawler to be really top heavy? Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-04-2012, 12:53 PM | #4 |
Rock Crawler Join Date: May 2011 Location: Bama!
Yes
11-04-2012, 01:35 PM | #5 |
Damn so my option is too detail this body as much as I can? Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-04-2012, 03:35 PM | #6 | ||
| Re: micro scale body? Quote:
there are a lot of mods you can do to a cheap body to make it look awesome however. an example would be to bend a metal coat hanger to make a body cage, bumpers, and roof rack. and some cheap paint goes a long way with these bodies. (even silver sharpie on the details looks cool) you can use superglue and lego's (one on body one on frame allows you to take body off easily.) I've seen a lot of success with Velcro for trucks this small too. Last edited by Intashu; 11-04-2012 at 03:39 PM. | ||
11-04-2012, 04:48 PM | #7 |
The legos sounds awesome but what scale do I look for in a model? Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-04-2012, 05:15 PM | #8 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
| Re: micro scale body? |
11-04-2012, 05:20 PM | #9 |
1:24, or 1:20th. revell makes Tons of my favorites. The things to look for are the wheel base. unless you plan to make custom sized links your going to want to find a truck that has about the same wheel base as the Trekker (or micro rock crawler if you have that, which is a shorter distance) The Trekker has a 4.8 inch wheelbase from axle to axle, where a 1:24th pickup may be longer, and a Jeep may be shorter! Alot of people have had success cheap body's however... like this one: Road Ripper 4 X 4 OFF ROAD SPORT VEHICLE - Jeep Wrangler - Toys & Games - Vehicles & Remote Control Toys - ATVs & Motorcycles Turns out like this: Direct fit, light weight, and this one is my dad's he mounted it with velcro with great sucess. it IS more top heavy than stock, but honestly it just makes it feel more realistic to a real truck! |
11-04-2012, 05:24 PM | #10 | |
edit: I am a massive scailer fan. my true 1:24th jeep (it's purple not the blue one here) is a standing testament to that. it is however much smaller than the stock Micro rock crawler... and not the best for actually taking on crawling. i does however look kick ass when it's trying to. Last edited by Intashu; 11-05-2012 at 02:44 PM. | |
01-20-2013, 01:14 AM | #11 |
Newbie Join Date: Aug 2010 Location: belleville
with the jeep body is it top heavy i had to remove the springs from mine to bring down the center of gravaty
01-20-2013, 09:51 AM | #12 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
There are some new bright 1/24 scale rcs that work really well for the crawler im no sure about the trekker tho. I have a ford raptor body that is the same blue as the stock bead lock rings and it looks awsome. Its pretty light weight too. They also have a jeep brute truck one but i have not found it yet. They are priced about $12 so its not bad i have seen them at walmart and target
01-20-2013, 09:55 AM | #13 |
Anything not made of the thin lexicon plastic that the trekker body is molded from will make the truck heavier. it anything it makes the truck more scale with plastic body's, but metal are just too heavy for most applications. Droop setup (no springs on shocks) helps combat that a lot however.
01-20-2013, 11:04 AM | #14 |
Quarry Creeper Join Date: Dec 2012 Location: Canada
Im using a 1/25 scale H1 snap tight on my trekker now with miclaws (big a$s) tires and the wheel base is good. I also have bwd wheel wideners which makes the tire to tire width look ok especially with the big tires. with miclaws with boggers I'm also using a 1/24 77 revel gmc pick up body which is heavier than the H1 and creates a lot of body roll - which I'll have to remove the springs to correct for sag suspension Scale bodies with detail look great, but, are heavy, can create body roll and might not be the best for hardcore crawling. If you can find a light body then go for it. If I wanted to do any hardcore crawling where weight, ride height ect plays a big roll, then i'll be using stock trekker body or make a comp chassis. just my 2 cents - I'm a noob and only been in this aspect of the hobby for 2 months. |
