01-24-2013, 12:58 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| RedCat SUMO speed?
Hello. I´ve got a red cat Sumo and I´m very happy with him, but I need a little more speed. Now I´m running a 2S and 350 mAH lipo. What could I do? Thank you very much PD: please excuse me, but my English is not very good! |
01-24-2013, 06:41 AM | #2 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: RedCat SUMO speed?
Get your hands on an 80T 130 Can Motor. Danally can hook you up.
01-24-2013, 06:46 AM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: RedCat SUMO speed? those motors dont just bolt up and last i knew Dan didnt offer a sumo kit. replacing the bushings with bearings helps some but swapping the transmission from a losi micro would give you more speed as well as allowing motor upgrades from Danally
01-24-2013, 06:47 AM | #4 |
My bad. Spoo is right. Get a losi transfer case and get an 80 Turn Predator 130 can motor.
01-24-2013, 07:11 AM | #5 |
that would be much faster |
01-24-2013, 07:42 AM | #6 |
And get some mini-qlow tires... They won't make it faster, but they'll make it MUCH more fun!!!! |
01-24-2013, 09:15 AM | #7 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
It depends on how much more speed you want & how much you want to spend to get it... I would not recommend a losi trans & 130 can on stock sumo electronics.It won't do you any good.. This setup wouldn't cost you much & has good performance... A losi trans 59t spur & 12t pinion, 70t pn racing motor fitted with neo magnets running on the stock losi micro crawler electronics with 2s lipo would give you something like this Mudder. - YouTube |
01-24-2013, 09:49 AM | #8 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
This would also be an option.. I've not tried it with the redcat motor on it yet but this gearhead runs 200rpm at 12V. When I ran it with the OE motor it was about twice as fast as the stock recat setup but didn't have enough torque on 2S. I can not by hand stop this setup while gripping a driveshaft so this may be the ticket. BTW these 16mm gearheads are a direct bolt on replacement, one the "plastic box" is removed from the face of the transmission and you would just need longer motor screws. I ended up using two screws from an old duracraps servo |
01-24-2013, 01:50 PM | #9 |
Thank you very much. So I´m going to buy a micro losi tranny and motor. I´ve been looking for the tranny but I´m not sure of what I need to buy!! Please, could you tell me if these are the both parts that I need? Do I need some thing else? Losi: Center Transmission Case and Motor Plate Set: McRC: Losi (LOSB1710) Losi: Ctr Transmission Gear Set, Slipper & Pinions: McRC: Losi (LOSB1709) |
01-24-2013, 02:23 PM | #10 |
You will also need losb 1713 & screws for the case |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/losi-micro-rock-crawler/424706-redcat-sumo-speed.html | ||||
redcat - forum communication | BoardReader | This thread | Refback | 02-22-2013 02:43 PM |
RedCat SUMO speed? - Similar Threads | ||||
redcat sumo lipo cutoff | RootBreaker | Micro Scale Rigs | 0 | 12-27-2012 08:28 AM |
Redcat Sumo - Complete | Rob L | Losi Micro-Rock Crawler | 0 | 09-16-2012 06:17 PM |
Redcat Racing 1:24 Sumo Crawler | RCGecko | Chit Chat | 1 | 03-05-2012 05:47 PM |
Redcat sumo help | Drummer | Micro Scale Rigs | 4 | 12-20-2011 08:15 PM |
