01-27-2013, 02:00 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| Parts of center transmission of micro losi?
Hello. I have a Red Cat Sumo and I´m going to mount a Losi center transmission and I´m very lost!!!!! So I need a new complete centre transmission of micro losi, motor and pinion for the motor. Please could you tell me what parts I need? Do I need bearings? And the pinion for the motor, what size is it? And the motor, the "normal" or the "hight power"? I want that the micro can go as far as a person walking but that it can crawler too. I think that I need: Center Transmission Case and Motor Plate Set: McRC Ctr Transmission Gear Set, Slipper & Pinions: McRC Losi Center Transmission Shaft Set: McRC Do I need some thing else? Thank you very much. |
01-27-2013, 08:16 AM | #2 |
Newbie Join Date: Jan 2013 Location: Greenfield
| Re: Parts of center transmission of micro losi?
You need the screw set LOSB1724. The bearings LOSB1728 2x5x2.5mm Bearings, 4 bearings total according to the exploded view drawing in the manual. That being said, it really looks like two of the bearings are bigger than the other two. I haven't ever taken my transmission apart so I am not completely sure about the bearing sizes.
01-27-2013, 08:48 AM | #3 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
There are two bearing sizes in the transmission. I believe the other is the 3x6x2.5mm bearing, but I don't honestly remember off the top of my head. You should also buy a Hot Racing transmission case (buy the Losi case so you get the motor mount plate) to prevent transmission binding. The plastic case flexes and heats up and will cause bearing failure. The Hot Racing case makes a huge difference in preventing that.
Parts of center transmission of micro losi? - Similar Threads | ||||
1/24 Losi Micro Crawler Parts ?? | defsaturn6501 | General Crawlers | 3 | 12-07-2009 06:41 PM |
