03-04-2013, 05:16 PM | #1 |
Newbie Join Date: Jan 2013 Location: Canada
| DP Torsion chassis for TT?
Anybody running them? are they worth getting?
03-04-2013, 05:36 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: DP Torsion chassis for TT?
This thread might help you out NEW Chassis for Micro Crawler I've been running one and really love it. I initially had the adjustment screws too tight - so run them pretty loose and you'll have some nice, but limited articulation. I for one, like limited articulation- too much makes my rigs floppy. The truck will be lower which is great for COG, but it can hang up on pointy rocks because of reduced clearance. I think the torsion chassis gains you control,simplicity and lower weight |
03-04-2013, 07:19 PM | #3 | |
| Re: DP Torsion chassis for TT? Quote:
03-04-2013, 08:38 PM | #4 |
Yes they are diffrent chassis as you probably know so buy the correct one. Here is my thread on the DP torsion chassis : Make your own torsion chassis... |
03-04-2013, 11:07 PM | #5 |
Pebble Pounder Join Date: Nov 2012 Location: CO
I don't like mine on my micro rock crawler. It's stiff, probably because it isn't broken in yet either but I'm going back to a shock chasis It's nice and simple though which is a benefit but I can't get it to flex Last edited by jprock; 03-04-2013 at 11:12 PM. |
03-05-2013, 01:00 AM | #6 |
| Re: DP Torsion chassis for TT? Have you tried backing out your screws almost all the way? It really helps
03-05-2013, 07:40 AM | #7 |
| Re: DP Torsion chassis for TT? |
03-05-2013, 02:14 PM | #8 |
Well it's only $18 at thetoyz.com for the TT version, I think I'll give it a try and if I don't like it, just switch back lol
03-05-2013, 06:04 PM | #9 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
When i eventually get mine in the mail i too was thinking about getting the torsion chassis. To bad they don't make the dyeable one for the trekker. I may boil it just because to get a softer feel. Does anyone know if i could use the micro crawler chassis on the trekker or will the trekkers wheel base not work with that?
03-06-2013, 04:25 PM | #10 | |
I think it'll work, but the mcrc's wheelbase is shorter then the mc4x4's | |
03-06-2013, 05:34 PM | #11 | |
03-06-2013, 07:53 PM | #12 |
At which i would be converting it to a micro crawler. Well i'll probably just get the one for the trekker. Thanks for the input
DP Torsion chassis for TT? - Similar Threads | ||||
torsion chassis.... | cumminsontherocks | Redcat Crawlers | 5 | 02-21-2011 07:03 PM |
trying a torsion chassis | prusik333 | RC4WD Bully | 3 | 05-11-2010 06:07 AM |
DP torsion chassis! | losilover | Losi Micro-Rock Crawler | 16 | 04-21-2010 06:48 PM |
Torsion chassis | hardhead | General Crawlers | 9 | 10-22-2009 03:57 AM |
torsion chassis cc | Donald919 | Duratrax Cliff Climber | 6 | 06-28-2009 11:50 AM |
