Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: RootBreaker's Micro Raptor V8e
Old 05-20-2015, 06:50 PM   #41
Default Re: RootBreaker's Micro Raptor V8e
Tnight stole front axle from mud truck as it has aluminum. But nothing ever just works.
Had to swap axle shafts between axles.
Next need to figure how i will get esc hidden in there and if battery will go inside or on back axle.
Step 1. Axle in. Powered on and 4ws works...
Sent from my Samsung Galaxy Note 3
RootBreaker is offline   Reply With Quote
Old 05-20-2015, 06:54 PM   #42
20150520_204328 by Jeffrey Riggs, on Flickr
Old 05-21-2015, 06:15 PM   #43
You could try splitting the pack and put it on either side of the motor and tranz, i did that on mine, not sure if it will work with the big block in there tho, looks tight. glad to see you back at it.
MikeChino is offline   Reply With Quote
Old 05-24-2015, 05:30 PM   #44
Yeah n o room...
I think it will fit in there. I dont need to use 380mah.. 180mah should do as i font play till a pack dies.
Old 06-19-2018, 05:38 AM   #45
3y later.. she will be coming out of retirement soon...
Old 01-25-2023, 03:59 PM   #46
6/18 I said coming out of retirement...who knew would take this long.
4WS complete. Electronics worked out but got to work on links...
Used Redcat Sumo Micro ESC and golden. I desoldered the pins from esc and it sat from 2018.... just soldered the servos in and boom. she is alive.
test bench.. check oit my other videos as I am going through my stuff and getting the complete ones working then need to build the others...
https://youtu.be/fdXBhUoJo48
RootBreaker's Micro Raptor V8e - Similar Threads
R7R Micro Raptor vs Blade TMC Micro Chassis??? ESC Losi Micro-Rock Crawler 2 09-06-2011 10:17 PM
Portuguese Micro Raptor zogada Losi Micro-Rock Crawler 2 04-28-2010 05:46 PM
raptor v8e chasis rccrawlking Losi Micro-Rock Crawler 5 03-15-2010 05:10 PM
micro raptor V8e losilover Losi Micro-Rock Crawler 2 02-05-2010 07:17 PM
