10-08-2013, 01:51 AM | #1 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Best motor/gearing for 1s or stock 4.8V pack?
So here's the deal, I'm building a scale Jeep TJ based on a 4 1/8" wheelbase, Trekker width, and a DP torsion chassis. Currently I have a 90t Predator in the rig, running 58/10 gearing. The small rig doesn't leave a lot of room for a 2s pack. I'm limited to a stock pack under the hood or a small 1s LiPo. Are there any other motors out there that will perform any better than my Predator on limited voltage? Maybe a 55t 130 or something? Somebody has to have some input here...
10-08-2013, 07:31 AM | #2 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: Best motor/gearing for 1s or stock 4.8V pack?
hope ya figure it out... im hearing 55t has no low speed. of course we will wait for Danally to confirm a recommendation!!! HAH... so you go the DP Torsion chassis already?? NICE... i didnt get your box yet but looking forward to it! |
10-08-2013, 08:36 AM | #3 |
Normally a 55t wouldn't have a lot of low speed, but this will be on a lot lower voltage. A 90t on 4.2-4.8v would be SOOO slow. The predator does alright on 4.8v, but still stalls out occasionally. I'm just looking for the most grunt I can get with the smallest battery possible.
10-08-2013, 09:35 AM | #4 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
i have a 55t stroker and it has pretty good low speed
10-08-2013, 10:00 AM | #5 |
Newbie Join Date: Oct 2013 Location: indiana
Edit, I can add photos later if you want to compare photos of the original losi batt to the 250 venom.I think the venom lipo is actually smaller, its a little bit thicker but only 2/3 the width of the losi nimh.Mine has been easier to mount, its so much lighter velcroe holds it a lot better.I had them under my trucks bed and the nimh wouldn't stay with the velcro I was using very well, but the lipo is really secure. Sent from my BNTV600 using Tapatalk 4 Last edited by cycleguy; 10-08-2013 at 10:07 AM. |
10-08-2013, 01:00 PM | #6 |
RCC Addict Join Date: Jun 2007 Location: MESA
I am not sure that you will find what you are looking for. Voltage is one thing that a motor can not make up for. You can do a faster motor like a 55 turn but it will hurt you a ton on the slow take off...it will require a lot more throttle to get it to move against an obstacle. If you wan to see it in an easy comparison, try your stock motor again and it would be close to that. As for a 130 motor or stroker? I have never run one on a single cell. I bet it would be better but only to make it slower. Any attempt to make it faster will have grave results on the rest of how it runs. My only recommendation is to try to find 2 single cells and make a second spot in the chassis for the other. Then make a harness to wire them in series to make 7.4 volts to the ESC. I have done this before when space was tight. There is no substitute for voltage/amps! |
10-08-2013, 01:57 PM | #7 |
That's another problem in it's own Dan. I don't even have room for 2 seperate cells. The space I have for the battery is around 40mm long x 30mm wide x 8mm tall. I'm thinking of going back to my 80t Predator, running a single cell, and just enjoying the "double low" factor. The 80t should have a little bump speed over the 90, but that's probably the only difference.
10-08-2013, 02:20 PM | #8 |
I remember seeing a jeep with the same problem.You could always build a small off road style trailer to tow a larger battery as you wish.Its a last resort solution, but a flexible one at least since you can unhook the trailer.
Best motor/gearing for 1s or stock 4.8V pack? - Similar Threads | ||||
Over heating motor with stock gearing! | ms4x4outlaws | Axial Wraith | 2 | 12-02-2011 07:57 PM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
motor and stock gearing? | ped453 | Newbie General | 1 | 11-23-2009 02:37 PM |
stock gearing? | bigblazerboy | HPI Wheely King | 9 | 12-19-2007 02:10 PM |
Which lathe motor for WK stock gearing? | MikeSSS | HPI Wheely King | 6 | 05-10-2007 09:15 PM |
