10-28-2013, 07:57 PM | #1 |
Quarry Creeper Join Date: May 2013 Location: Chino
| Mini/Micro/Super? So I ran my Super micro most of the weekend, well the times it didn't break drive shafts that is. I start looking in my parts box to see if I have anything that would make it stronger, I found my stock Losi MRC drive shafts, and I'm thinking man that would hold up much better, well long story short, it would take a bit of modding to get them to work with the Sumo axels and I would still have to figure out the gearing motor issue. So then I flip over my Mini MRC and take a few quick measurements, the axels could be cut down the trans, skid, and chassis would need to be made, but if I got it all to fit ,the motor would stick out of the side big time, but it would be pure beef, and I would be able to run the big motor, big tires without the breakage. I am just thinking out loud, anyone else ever do anything like this to basically turn a Mini into a Micro? Upside? Downside? what do you guys think am I loosing it? |
10-28-2013, 08:44 PM | #2 |
RCC Addict Join Date: Jun 2007 Location: MESA
| Re: Mini/Micro/Super?
Just too big imo. Do u have one to try?
10-28-2013, 08:50 PM | #3 |
Yeah i have a spare MRC that's been just collecting dust, i might just start with cutting down the axels to see if its just to much, next to a stock micro its way bigger, but with the mini8 rims it might make it look ok, if not i will most likley just try to get the drive shafts to work, that alone would help big time.
10-28-2013, 09:35 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
It's not to bad modding the mrc shafts..They are big but they bring the beef On sumo axles I mod the axle pinion shaft with a 1/8 music wire turned down & flattened in the right places & longer than stock...Then sleeve the inside of the mrc drive shaft with 5/32 brass tube with a grove cut into it for the grub screw to pass through...Bomb proof drive shafts is what ya get! Haven't broke one yet! On the chev mud skipper: MRC axles to micro Thats crazy talk, way to bulky! Last edited by chevy55; 10-28-2013 at 09:39 PM. |
10-28-2013, 09:48 PM | #5 |
| Re: Mini/Micro/Super? That's what I'm talking about |
10-28-2013, 10:29 PM | #6 |
The music wire is 1/8 or if your lhs has K&S swag its stock #5o7 & the brass tube is #128... The shafts are crazy strong if ya need any help with it, hit me up! I run them on my SB with a 1/18 bl setup & widened sumo's they hold strong & this thing is fast: Also in my ttc silverado with widened sumo's, this monster has tons of torque & wheel speed with the 180 can & 29:1 reduction box...Ran through a modded red cat trans for the t case: Last edited by chevy55; 10-28-2013 at 10:32 PM. |
10-29-2013, 08:24 AM | #7 |
| Re: Mini/Micro/Super? I have a local metal supply shop near my office, I'm going to stop by on my way home. looking at the pictures, I missed the part about turning down the piano wire, did you use a lathe? all I'm working with is a drill press and dremel lol. I will still give it a shot because the drive shafts are definetly the week link, and thanks again for the pictures that helps so much. |
